exhaust question
Discussion in 'The Garage' started by slackjawsk5, Feb 3, 2006.
  1. slackjawsk5
    slackjawsk5 Registered Member
    Jan 29, 2006
    38
    berlin,wisconsin
    hey guys i was wondering what would cause whitish grey exhaust to pour out only on of my tail pipes. the engine sounds good, thought it could be a head gasket or something what do you guys think
  2. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    is it after the truck warms up or when its cold, your question is very short and not a whole lot of info.
    im guessing all the time but i say a leaky intake or head could be the culprit. i had a intake gasket go on a 305 and it poarded white til i change them....
    LUKE
    just a thought
  3. goldwing2000
    goldwing2000 Guest
    Yep... sounds like steam.
    Head gasket, cracked head or cracked cylinder wall.
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    which tail pipe, and what trans are you running?
    if a trans with a vac. modulator(350/400) and the vac line is to a runner on one side or the other(I have seen most to the runner for #8 cylinder, pass side) , and the modulator is bad, it will suck trans fluid into the runner
    p.s., trans fluid burns white
  5. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    If it is grey, it could be running too rich. A rich mixture cuases grey smoke. coolant causes white smoke. try the smell test on your exhaust. If it has a sweet smell it is coolant. If it is gasoline, then it will have a chemical type of smell.
  6. goldwing2000
    goldwing2000 Guest
    Last I checked, too rich caused black smoke. :thinking:
  7. dave_90_blazer
    Jan 1, 2004
    688
    just slightly rich is grey
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Black smoke is normaly a sign of burning oil.
    Black smoke = oil
    White smoke = water
    Grey smoke = gas
    But this is not written in stone or anything.
  9. goldwing2000
    goldwing2000 Guest
    I think you got your gas and oil backerds. Oil definitely produces whitish/blueish smoke. I get reminded of this every time I start my Blazer. :D
    I suppose grey could be taken for blue so it could be an oil burning issue. And if there's that much oil burning, then the transmission vacuum line is definitely a good place to start looking.
    Just to coroborate: http://www.bellaonline.com/ArticlesP/art10101.asp
  10. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    if the vaccum modulator is bad will that make the engine lack power
  11. dave_90_blazer
    Jan 1, 2004
    688
    it would definately effect transmission shift timing/quality(which can be mistacken for power issues) and the oil can foul the plug/s as well
  12. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    thanks guys ill have to try that
