Exhaust question
Discussion in 'The Garage' started by 84 K5 4x4, Jan 18, 2007.
  1. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I have dual exhaust running straight out the back with tips on my k5 and when the back glass is down exhaust fumes pour in. Is there a solution to this problem without adding a wing on top. :confused:
    84 k5 350/465/205/14ff detriot 10b open 4.56
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Do what the cool kids do (me :p:) and dump it at the axle or just over it if you like your rear-end clean (:confused:). Take the :hack: to your exhaust and you'll be :thumb:.
  3. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    My Blazer was the same way, So I Put new mufflers on and turned them out in front of the back tires. This fixed the exhaust problem, but it's very very loud!!!!
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Very Very load is what im looking for:D:D:D
  5. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Yeah, but isn't that how we like it? I know I like waking up the cops from their afternoon nap with the sound of a 350 singin' through a 3" high-flow cat and a Flowmaster Super 40 accompanied by buzzing 39.5" Swampers... (Me=>:blush: :yikes:) (:deal: <= Cop)
  6. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I bought some used mufflers off of E-bay for $15. I don't know what kind they are, I know they're not Flowmasters. I used 2 1/4" pipe for the 305 and they pop really bad like glasspacks. I wish I would have put 3" on the back side of the muffs!
  7. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Well, if it's a true dual set-up (i.e. no H-pipe or X-pipe), it'll pop a little, but if it's popping a lot, you've got some nasty backpressure issues. Put in an H-pipe (really simple; shouldn't cost more than $50 bucks at a reputable exhuast shop), and if that doesn't fix it, get some different mufflers.
    Mine's got a custom 2.5" y-pipe going into a 3" cat and Super 40 out dual 2.5" turn-downs. Made a big difference with the power and smile-factor of my :k5:.
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have true dual on my 350Sb In my blazer and it doesn't pop at all. Is this OK?
  9. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
  10. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Yeah, that's perfectly fine. It's just the style muffler you have on it. Some pop with backpressure variances, some don't. Higher quality ones don't.
    And Elevator Man, it's the style muffler you have that is making it pop a lot, but if I were you, I'd really consider having an H-pipe put in. It's much better to equalize the backpressure out the cylinders to promote better scavenging (i.e. power). Plus it'll have a bit of a deeper tone to it; not sound like two 4 cylinders firing off against each other. It's all about personal preference though...
  11. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i would run it out the sides either behind the tires or before. that should stop your fumes
  12. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    bigblazer87, what would be better a H-pipe or a x-pipe or does it matter? I want a deep "Flowmaster" soud instead of the "glasspack" sound. If you look into the mufflers I have you can see a pipe with little holes all through it. i guess they are like a turbo muffler. I don't mind the loud I just don't like the pop!!!
  13. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    An X-pipe would be best, but with the short wheelbase of the Blazer, it might be hard to fit one in. If that's the case with your's, just go with an H-pipe, it'll work nearly as well. If you want a Flowmaster sound, you'll have to pony up for some Flowmaster mufflers (because those glasspack "Turbo" mufflers will never come close to a Delta style muffler), or you can get them cheap used off eBay or sometimes from the muffler shop (my muffler guy always has some spare ones around).
  14. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I know I'll never get the "flow" sound I'm just saying that I want a deeper tone instead of the poping sound. I've had flowmasters on about 4 trucks and a few with glasspacks. does it matter where I mount the H-pipe? How far back?
  15. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    You'll want to mount the H-pipe about halfway between your headers and your mufflers. If you get me some undercarriage shots, I can show you a good spot to put it for the best clearance and performance.:waytogo: But if you take it to a good exhaust shop and tell 'em what you're looking for, they'll know what to do and how to do it the right way. Try to find a guy who's been doing it for a long time on his own; I try to support my fellow hobbyists before the big businesses.;)
  16. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I do all my own muffler work, my family owns a fabrication shop. I work on Elevators but I have full acess to our shop, we have 2 two post lifts and two four post lifts. I,ve just been trying out the cheapest route. I'm just to tight to pay $80 dollars a piece for flowmasters.
  17. goldwing2000
    goldwing2000 Guest
    I'm actually running four mufflers. True duals with a flowmaster and a glasspack on each side.
    Before I added the glasspacks, I had to drive with earplugs. :eek1:
  18. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    What about 800 hp to push the exhaust out?????
  19. goldwing2000
    goldwing2000 Guest
    It's less restrictive than a single exhaust with a catalytic converter, which is what it came with from the factory.
    Glasspacks don't make very much restriction. :rolleyes:
  20. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yea I have true dual flowmasters no X or H pipe and no poping ever! Should i still go se if they can install an X or H pipe to make a deeper tone?
