exhaust question
Discussion in 'The Garage' started by efilnikufecin, Jun 18, 2002.
  1. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    just want some opinions on exhuast placement.what is the best way to route exhaust on a K5 so i don't get any fumes inside when the back window is down.is this possible?i got turn downs before the axle on my 78K5 and get a pretty good amount of fumes while driving down the road with the back window down.i want to put some exhuast on my 91K5 and wanted to be able to run with the back window down.thanks
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    There has been a lot of discussion on this topic here. I think that the general conclusion is that if you route the pipes out the side, You will have a much better chance of not getting fumes. The very nature of the Blazer ( Big box going down the road) causes a pocket of air to follow along with it where the fumes like to gather. Opening the back window gives it a place to go. Routing out the side will most likely be your best bet.
  3. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I have mine routed just behind the tires. The thing I notice with the fumes- if my window's down, of course, the 2 door windows are down too, but If I open the floor vents, the fumes are a lot less. also, I only notice fumes while driving around town, once I get up to 4th gear, no fumes
    try the floor vent trick
    Brandy
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've had mine routed both behind the tires and straight out the back, and I can't tell a difference b/c I got a lot of fumes with both setups but I haven't tried the vent trick. hmm.....
