Exhaust question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Muddytazz, Aug 1, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm runnin single right now with a 350 and I wanna go dual. I'm thinking about runnin 2 1/4 or 2 1/2 Dynomax, but what is the purpose of a H or Y pipe?
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Balances the pulses between the two pipes. This reduces noise and creates more power.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    which would be the better pipe H or Y or does it really matter, and what would be a good size pipe to run...2 1/2 or 2 1/4? I'm gonna replace from stock manifold to rear.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> A y pipe is generally used on single exhaust, it brings the exhaust from the two cylinder banks into one tube. The H pioe is used on dual applications. There are X pipes too, but they're hard to do on a 4x4 becaiuse of the limited space available. I'd go with 2.25" pipe over 2.5, unless your enging is worked over pretty well, like 350+ HP. The smaller pipe will help keep the torque meaty in the lower RPM range.</font color>
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    2.25 pipe will work, cause I've just got a stock 350 right now, want to eventually put in at least a RV cam.
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Do you mean X-pipe? The X-pipe is just another version of the H-pipe that works better. Problem is it's VERY hard to find room under a 4x4 to have them come together and split back out with out them being crushed from hanging too low. A Y-pipe is what you have on there now more than likely. It takes both sides and makes it into one pipe and then all the way out. I believe that you can do dual 2 1/4 into a 3" single pipe (Y) and not have any restrictions because they flow the same. My personal preference is true dual's. I hope to be putting an H-pipe on my blazer soon. As for Pipe Diameter I have 2 1/4 on one of my trucks and 2 1/2 on the other. I like both. Some will say that one or the other will make more power but I believe that the 2 1/4 would be better for a 4x4 because it will make more power on the bottom end and less on the top end. I hope this helps you some.
    James
  7. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Sorry to repeat. I'm just a slow typer /forums/images/icons/laugh.gif
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    lol...i'm a slow typer also!
