Exhaust Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Oct 30, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    Right now im running a 400ci SB with Edelbrock carb and manifold,Hedman Headers, 2.25" pipe out to 2 Flowmaster 4 series. Im planning on changing that set up. I want Hooker Competition Headers with 2.5 -3" pipe back to 2 Flowmaster 50 series. Will that sound ok? What should i do. The 40's are too loud and the pipe is rusting, plus the headers suck. I want a whole new set up. What will the cost of the pipe cost me? I want about 3" straight back and then cowboy cut (/ \) out the back end. Thanks alot! /forums/images/graemlins/k5.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 3" duals is way too much pipe for a small block if you want any kind of low end torque at all. Stick with the 2.25 if you stay dual, 3" is fine for single. You may be able to save some money and reuse the headpipes that's already in there, just have it cut off at the mufflers, put on the new mufflers and your tailpipes. </font color>
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the backpressure will come from the muffler, pipe diameter has a little less to do with with it, imho.
    ryan
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I disagree, most quality mufflers flow pretty dang well, regardless of how much noise they produce. Dual 3" pipe with a 50 series on each side is way to much flow. </font color>
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I don't agree with you.... I have 3" true duals.......the truck "low end" hasn't changed since they were installed. The previous owner is a good friend of mine, and I drove it back when it was first lifted, and that was before the duals.
    How much low end should I even have considering its a 305...you won't lose enough to make it noticable....more often that not, you'll feel a bit peppier...
    Brandy
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Well, it's a 305... I mean, you can't polish a turd... /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/wink.gif How are you going to lose low end when you didn't really have much to begin with? /forums/images/graemlins/grin.gif
    I know that I'm not ouit in left feild here, but I don't have the engineering knowledge to back up my claims, just real world experience. Maybe someone smarter than me can explain why you lose low end torque with larger diameter pipe. /forums/images/graemlins/thumb.gif</font color>
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Go with corvette exhaust manifolds.
    I did and got Flowmaster 50's, 2.5" true duals.
    Nice.
    -- Mike
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Listen to Shaggy- don't go bigger than 2 1/4 with performance mufflers.......
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Hooker Headers !!!!!!!! /forums/images/graemlins/thumb.gif!!!!!!!!!! /forums/images/graemlins/thumb.gif!!!!!!!!!!
  10. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    if you are going 3" into a single muffler and out either 2.25 or 2.5 you should be fine.. 3" in and out the back will burn up some valves pretty quick...the back pressure gives you a bit more torque. General rule of thumb, bigger pipe alows for more HP which is gonna usually be closer to to top end....midrange pipe 2.5-2.25 is gonna be a good balance of torque from back pressure to the motor and HP from better free flowing than stock. Also more HP and less torque means more gas spent off the line getting going.... I have run a 40 series with turn downs....nice HP, when i added the rest of the 3ft out the back in 2.5 with tips made a world of difference, I could feel and hear the back pressure difference..pedal seemed a bit stiffer and engine idled loads smoother. On my blazer i went 1 in 2 out 3" from the headers all teh way through the high flow cat into the 50 series delta flow and dual 2.25 out the back...big differnce in flow from the 3" into dual glasspacks, out 2.5...
    I guess what it boils down to is how your engine is built....if its fairly stock (not a race engine or BB) 2.5 serves all your needs fine
