exhaust question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigtruck87, Jul 6, 2003.
  1. bigtruck87
    bigtruck87 Registered Member
    Mar 19, 2003
    33
    Treton, NJ
    ok i will be buying the edelbrock t.e.s. headers for my truck but before i order them i have a couple of questions.
    1. What lenth header bolts do i need? i'm going to try and use the new style that breslin makes. the one with the little allen head screw in the middle to make that locking. but they offer them in both 3\4 and 1 in long and i dont know which i need.
    2. what kind of gaskets do i need square port or round port? maybe that is a dumb question but i have no clue so any help would be nice. also any suggestion on brand of gasket so i dont buy something that sucks and have it blow?
  2. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    1) I would go with 1", the flanges on the TES headers are like 1/4" thick, so 3/4" would probably be too short and wouldnt give enough grip.
    2) if its a SBC, get the square port gaskets.
    -Oh and if I were you, I'd just buy some full length headers like the Hedman Elites. For the price of that TES setup, you could buy headers and a brand new exhaust system. But the TES headers are nice since they bolt right on. just my 2 cents.
  3. bigtruck87
    Mar 19, 2003
    33
    Treton, NJ
    i would like to buy cheaper headers, but i live in n.j. and the emissions are strict. so i need to keep the air injection. and as far as i know the only headers the let you keep the air injection are the edelbrock t.e.s. kinda sucks cause there expensive but i love my truck so what the hell. edelbrock t.e.s, 3in high flow cat, and 3in single piping.
  4. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    You better check your sources again, hedman,doug thorley,and JBA make headers with both the o2 sensor and the A.I.R. injection. The JBA's are about $650 but the hedmans go for $265 from summitracing.I have the same problem here in california.
    85' K5 3/4 ton 35" boggers,16.5x14 welds,9"lift big horse 406SB/corvette 700r4 /forums/images/graemlins/k5.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The TES system comes with header bolts and all needed gaskets.
    I just used what came with mine. Have had them on over 4 years now with absulitly no leaks.. I just re torqued everything after about two weeks and I haven't layed a wrench on them since.
  6. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    I have always used stock manifild gaskets and and long as you keep an eye on the bolts and dont let them back out they will never blow out. Even if they do get loose they wont burn near as easy as the gaskets that come with the headers. Thats the cheap way out. If you want to spend lots of money go buy the copper ones. Personally Im cheap and i have never had the manifold gaskets blow out as long as I kept the bolts tight. As far as headers everyone elses suggestions are better than mine i dont live in an emissions county so i dont have to worry about it.
