Exhaust Question
Discussion in 'The Garage' started by the_goat, Nov 11, 2003.
  1. the_goat
    the_goat 1/2 ton status
    Sep 13, 2003
    113
    Phoenix, AZ
    Is a single 3 inch exhaust to much for a stock 350? It's in an 84 Jimmy with 35's,4.10's and a 700r4.
    John
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Nope some say its better than 2.25 duals. I have single 3" on my 90 and love the way it sounds too. /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If 3" was too much, the factory wouldn't use it. /forums/images/graemlins/smile.gif
  4. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    No its not too much.
    I honestly believe you would be better served with cross-over duals, 2.25" but thats opinion. either way, the 3" single shouldnt be too much.
  5. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I will 2nd that
  6. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    What is the big advantage to a crossover pipe?
    Trey
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    back preasure /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. boggerless
    May 26, 2003
    22,728
    96
    unless i'm wrong, won't be the first time /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. Topdown
    Nov 26, 2002
    2,598
    builds torque because it scavenges the exhaust fumes and creates a "low" pressure, almost vacuum like.
    When the right side fires, it creates a low pressure vacuum in the left pipe, so when the left side fires it essentially sucks the fumes out of the chamber as well as the engine pushes them out. So you flow more/better and build better power. plus an equalizer pipe or a cross-over will smooth out idle and I personally think they sound much better than straight duals.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that. My tow rig has a crossover and sounds great!
  11. the_goat
    Sep 13, 2003
    113
    Phoenix, AZ
    Thanks for all the replys. I didn't know that 3inch was stock, sorry.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not on everything, just on certain models. My 1 ton 2wd had 3" into 2 1/4" dual tails. It has 2 1/4" crossover duals now. /forums/images/graemlins/smile.gif
