Exhaust size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Dec 18, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I am looking at converting to true duals with dual cats and flowmaster 40s. What size pipe should I use? I have heard go with 3" if single exhaust and 2.5" if dual. Does this sound correct? I just need to order the right cats/mufflers.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I've also heard that going with too large of an exhaust reduces back pressure to the point where on a stock engine it can actually decrease performance. I have my theories why but honestly have never researched the matter. You might want to.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup that is what I have read. I wouldn't go any bigger that 2 1/2" pipe with duals some have even ran 2" to try and get more torque...I don't know the detail but I am running 2 1/2" and I'm happy[​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I am running a single 3" and dig it. Maybe its just me, but paying for 2 cats and 2 muffs? bah. Not worth it IMO. For high HP racing wanna-be rigs or something it might be cool, but 3" is plenty of room for my 350 to breathe through.
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    For what motor? Your tired one or the new one you're thinking of?
    On my 305, I had single 2 1/2" pipe. If you're gonna drop a 350 in, you really should decide how much HP and Torque you think you'll wind up running before you put several hundred into an exhaust system. Those flows will sound sweet on anything though [​IMG]
    <font color=blue>What part of my brilliance do you not understand?</font color=blue>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    This is for my new 350. I am expecting somewhere between 260-285 HP. I expect that I will either go 2 1/2" for duals or 3" for single.
    Brian
  8. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    psht exhaust, i just cut the mufflers off(no cats cause its a 76, exempt) and took some flex tubing and bolted it on and pointed it down. now thats wat i call an exhuast system.
    phill
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I run a 2 1/4" Dynomax header dual kit. It's CHEAP and you can get it from Jeg's High Performance.
    2 1/2" sounds better but if you're under 300 HP and 5,000 RPM or so, 2 1/4" is good enough.
    Tim
  10. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    <font color=green>2.5 inch shorty duals with Flowmaster 50's and crossover. It was highly recommended, and it really works...............................</font color=green>
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  11. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i'm trying to decide what i want too. i have the stock single exhaust and manifolds. i'm getting a crate motor next year but i want headers before then. i've been thinking of what type and brand to get. but i'm still not sure as to what i want.
    people that get good mileage aren't having any fun!
    scott,
    1989 GMC suburban 3/4t 4" lift rollin on 36" swampers, tbi350, th350, np241
  12. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    I've got a 350 with "true" dual exhaust, 2 1/2'' pipes, no catalytic converters (smog exempt), and dual flow master 40's and it sounds AND runs SWEET!!! The key to the whole system is you gotta have a cross over pipe linking the two pipes together to equalize backpressure of both of them. Trust me....this works!!!
  13. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Jekbrown is right. Why have two exhaust systems under your rig. JBA shortys, custom Y pipe, Flow master collector,
    Hi-flow cat &amp; Flowmaster muffler works great and sounds nice. My 3/4 ton camper special 454 had 2.5 duals &amp; Flowmasters. Two and a half inch duals on a stockish 350 is
    more than enough system. My 68 mustang has tri-y's 2-1/4
    duals w/Flowmasters &amp; that works good.-Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff & CV driveshaft
  14. jaybird
    jaybird Registered Member
    Nov 16, 2001
    21
    Arlington, Texas
    Brian,
    I run 2.5" on my Jimmy, If you run to large of exhaust you reduce port velocity to the point of not getting all of the spent gases out of the chamber. The smaller pipes will maintain heat in the exhaust gases and port velocity. go with 2.25 or 2.5 duals with a crossover pipe as close to the engine as possable.
    Jay
    Jay VT
    79 Jimmy 454, 700R4, NP208, D44, 14 bolt, 4.56:1, 38's
  15. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    the balls of exhaust gas going through the pipe actually creates a vacuum behind it whic helps draw the next ball of gas along...too big a pipe reduces this effect ("scavenging" i think)
    Shutup Brain or I'll stab you with a Q-Tip - Homer J. Simpson
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Take into account, majority of the published reading is based on "Street performance/Hot-rods". That means it's high RPM use (3-4 grand and up) and therefore, passes more air threw the engine. So, lager exhaust works. But.. for us... the RPM range is different.
    In theory, it's a game of vilosity(S/P?), not "flow".
    Atomispheric preassure pushes back on the exhaust pulse, so it works against the engine in pushing the exhaust out. But, if the exhaust pulses are correctly timed, and the diameter of the pipe is keept to a minimum (for the given RPM range), each "pulse" will pull the next. (get it?)
    What I'm tring to say is that: Operating RPM range should be considered, and for us, thats from idle to 4500, so 2.5" exhaust is to large (IMO), 2.25" or 2" would be better, to keep the air pressure at bay and out of the pipe at all RPMs.
    Back pressure costs.
    If the exhaust sys. is restrictive, the engine has to work harder to push the exhaust out. Any-back preassure will cost H/P. Anyone that says different, hasn''t correctly calibreated the Air/Fuel mix as needed after the exhaust work was completed. If the exhaust sys has a restrictive miffler or is bent exsessively, the diameater of the pipe should be increased as needed to compensat.
    In a nut shell, 2" or with high-out-put 350 (or larger cid), 2.25" dual with good flowing mufflers, crossovers equilize the exhaust pulse into a uniform flow, also help compensate for restrictions in the sys. (I think, if a cross-over is used, the next step smaller pipe could be used)
    In theroy according to Twiz.
    <font color=blue>Wow factors
    A SBC (4" X 3.48") with 2" intake-valve at 6,000 RPMs:
    1- The piston reaches a maximum speed of 60 MPH
