Exhaust smell after running at WOT...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Jun 9, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    When I'm on the highway and need to punch it to pass someone, I smell exhaust in the truck. It seems to smell a lot like PB Blaster... what could be causing this? I don't have any exhaust leaks, or if I do, they're not making any noise.... /forums/images/graemlins/thinking.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Sounds just like your catalytic converter. It's a really bad smell too, almost like spoiled eggs. Can't do anything about other than get rid of the cat.
  3. mudmuncher
    mudmuncher Newbie
    Oct 8, 2002
    4
    south louisiana
    Mine makes the same smell as you describe, almost like wd-40
    and i have no converter. Ive always wondered what it was....
  4. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    It's not that rotted egg smell...I know that too well. My S-10 Blazer smelled BAD like that when the injector unit went out. It just smells like someone sprayed PB Blaster (or WD-40) into my vent after I've had it to the floor...bizarre, right?
  5. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    Mine also has that same smell to it and the rotten egg smell the girls always love it. So should I just gut out my cat and put it back on or take it out all the way. Also will I need to get a muffler for some back pressure. Because right now it's just the cat.
  6. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    blazingboy, you should have always have a muffler for proper backpressure. the only engines that dont need backpressure are totally cammed out engines and such. a muffler will give your truck more low rpm torque anyday over a straight pipe
