Exhaust system for 1984
Discussion in 'The Garage' started by wags86, Feb 22, 2007.
  1. wags86
    wags86 Registered Member
    Feb 19, 2007
    24
    new jersey
    I have been looking for a complete exhaust system for my 1984 with a 305 V8. I am interested in installing headers, y pipe, perhaps a new cat and tail pipe sections. It can be either single or I would prefer a duel set up. Any ideas/suggestions out there? Thanks:bow:
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have the same rig as you. I opted for 2 1/4 pipes coming off the factory manifolds to retain the EFE valve for quicker engine warmups in the winter. We have no smog up here, so I eliminated the cats and decided on running a pair of Dynomax Super Turbos.
    Before you spend the dough on a complete pre-bent system, I suggest you stop by a local exhaust shop and see how much they'll charge you for a custom-bent setup. :thumb:
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i just did my 84. hooker comps. 2.25 straights into flowmaster 40series. then dumps under each tailight. i like it.lol
  4. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i have an 85. just bougth flowtech headers (100) and called around for options.
    ill put them on, and 1 shop will run dual pipes all the way back with flowmasters for 300 and another shop will run duals all the way back with turbos for 240.
    still havent decided which one i want yet. no cats going in
    2 1/4 pipe
    mine is a 305 also
  5. solidaxlesub
    solidaxlesub 1/2 ton status
    Feb 21, 2005
    171
    tri-cities, wa
    you can order a 2.25 -2.5 fully mandrel bent duel exhaust kit from hooker. can be ordered for headers or manifolds and dosent come with mufflers. I ordered one from PAW years ago, but have seen them listed a few months ago in catalogs. It will say its for "off road use only" because it eliminates the cat. hope this helps.
  6. wags86
    Feb 19, 2007
    24
    new jersey
    Thanks for the info. I will stop in or make a few calls to some local shops to see what they can do for me.
  7. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I have '84. I put on heddman headers and true duals. with 2 chamber flowmasters. I didnt have the cats put on. AFter a month of driving, the fumes were so bad and the noise was raspy, a lil too much for my taste, so I went back to muff shop and had 2 Catco cats put in. I didnt lose any power at all and it is now quiet and no more fumes.
  8. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    did you run yours out the back under the tailgate? i hear this is really bad for the flow. all the gas comes right back towards the truck.
  9. ghostrider32
    ghostrider32 1/2 ton status
    Apr 17, 2005
    117
    HOLDENVILLE.OKLA
    i seggest you put them out the side behind the rear shackle. I have 2.25 out of heddman headers through flow masters , fumes and sound was horrid when i had to cut them to do a shackle flip. Extended them 6 inches to come out behind the hanger no more fumes or raspy sound. deep and mellow
  10. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    yea mine are coming out the sides behind the shackles. no fumage for me!
