Exhaust system help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wes, Jul 11, 2000.
  1. Wes
    Wes Registered Member
    Apr 19, 2000
    7
    I have a problem. If I leave the rear window of my 85 K5 open which I like to do on nice days, I get a lot of exhaust fumes inside the cab. I was planning on redoing my system when it finnaly rotted out and I'm close enough now. Only thing to keep in mind, I drive in sub-zero weather with lots of snow about 4 to 5 months a year. On the other hand we don't have emissions testing here and so if my old system should fall off just before I take it in the mechanics will put on what ever I want and omit any unnessesary parts.
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Wes do you have a diesel? If not count your blessings. I have to practically wear a haz mat outfit while driving mine. try and dump the exhaust before the back tires out the side of the truck. The worst place is straight out the back. JS
  3. conv76jimmy
    conv76jimmy 1/2 ton status
    Feb 18, 2000
    281
    Yay Area, CA
    I have a complete exhaust system for sale. If you have an LMC magazine handy you'll see it in the exhaust section. It comes
    with all the piping for a dual exhaust 2 mufflers and all the hanging equipment. I bought it for my Blazer but in California we have very strict emission laws. So thats why I'm selling it for $140.00 let me know if your interested.
    you can get a hold of me here or email me at jlonaker@onecolor.com
    2-wheel'n all the way!!!
  4. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I used to have the same problem. I had my exhaust redone from the mufflers back. It's dual exhaust with glass packs, 24 inch echo tubes, and no catalytic converters. My new exhaust now empties out behind each back tire. Now I drive with the back window down with no problems. Sounds good too.
  5. imconfused
    imconfused Registered Member
    Jun 16, 2000
    44
    WES , DEFINATELY have your exhaust point out the side behind the tires!!! I too had the very same problem and just solved it today. I ran dual 2.5 with Flowmasters and sent them pointing outward behind the rear wheels. I am truly amazed at what a differance it made. Good Luck...
  6. scrapper
    scrapper Registered Member
    Jun 12, 2000
    33
    Wisconsin
    I am interested in this exhaust system if no one else has laid claim to it first.I sent for,and have not yet received the for mentioned catolog,so can you provide me with a litte details,where the system starts,and exits.
  7. conv76jimmy
    Feb 18, 2000
    281
    Yay Area, CA
    Starts from the exhaust manifolds and exits on each side of the rear tires it consists of all the piping, 2 turbo mufflers & all the hanging equipment so that you can do the job yourself. You can contact me here or direct to my email
  8. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    even with the ends pointing behind the rear wheels i can still smell a trace of fumes. i am getting one of those aero-wings for the top, i have heard good things about them to solve in cab fumes and to keep the rear window clean.
    Knife.
  9. 87JIMMY
    87JIMMY Registered Member
    30
    MN
    Yup the wings really help. I removed mine so I could park in the garage, but I put it back on right away so I could breath.
    Scott 87JIMMY
  10. 87Blzr
    87Blzr 1/2 ton status
    May 24, 2000
    111
    I see those dual exhausts for the seventies trucks but not for the eighties trucks. I am looking for a dual exhaust kit from the headers back (have the headers but not installed yet until I have a exhaust) dual pipes into two mufflers and exit out the side behind the rear tires. Do they make them for a 87 with 4wd?
    87 K5 Siverado, 68 SS 396 Camaro
  11. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I have stock dual's that come out behind the drivers side rear wheel. When I rode with the rear window down it was awful. I bought the Aerowing from GTS and it solved that problem as well as now the rear window stays much cleaner.
  12. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Well if you don't have one of those wings than reguardless of the exhause sys and how expensive you'll still get fumes in. The air becomes turbulent behind the vehicle because face it its a box with wheels and a motor and the fumes mix with this air and flows into your back window. The wing will force air from the top straight down over the window. This will also keep the back alot cleaner from dirt and other good stuff.
    Love, Peace, and Hair Grease...........
