Exhaust woes!
Discussion in 'The Garage' started by ecameron87, Dec 20, 2005.
  1. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    About 10-12 months ago I rebuilt the exhaust on my 72 K5. I installed Hooker headers and Flowmaster Delta 40's. It is dual exhaust with 2-1/2 inch pipe.
    As you can guess, I cannot get the headers to stop leaking and it is very loud! I have tried Percy aluminum, copper, cork, paper, and pure silicone for gaskets. It didn't leak when I had manifolds. I am now using OEM original manifold gaskets with "Red" high-temp silicone. This last fix works better, but still leaks.
    My question is, what methods do you guys use to find where the leaks are coming from? Does anyone else have any more techniques for leaky headers that I haven't tried?
    I have searched the forums and have seen this problem everywhere, but nobody comes back and tells us what cured their leaks.
    I am at wits end with this thing and am ready to go back to manifolds unless someone has a miracle cure.
  2. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Have you checked the headers for warping? I know headers leak fairly easy, but I've found that copper gaskets with [SIZE=-1]some rtv high temp copper sealant fixxes the problem.[/SIZE]
  3. erik59
    erik59 Registered Member
    Jun 4, 2005
    52
    Parkersburg, WV
    Have you checked to see if all the welds on the collectors are fine. I have never had a problem with percy's stuff. I have used them all and they were the only ones that would work on my Mustang GT. I would say that they are warped or they are leaking at a weld before I would say it is the gaskets. Are the bolts staying tight? Stage 8 makes locking header bolts.
    Since it is a 72 I would use a gasket buffer and clean up the mounting areas of the header and head since you have had so many gaskets on it.
    Just my .02
    Erik
  4. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    double the gaskets always worked for me 2 gaskets per each header
  5. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    I always cut away the extra steel btween the exhaust ports so each one will seal individually to the head.I also use stock exhaust manifold gaskets (FEL-PRO)and have never had my headers leak.Good luck!:D
  6. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    I have the felpro stock exhaust manifold gaskets on right now with high temp red silicone on them. I might try cutting the flange up as well. Any other ideas? Anyone know how to find where the leak is coming from?
  7. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    make sure the heads are dead flat and so are the headers, if not then they will always leak. GM makes a stainless steel manifold gasket, it is a 2 or 3 layer gasket and will not rust. I have never had them go bad. Try those because I would not use anything else. Any GM parts guy that knows anything knows about them. Since headers like to come loose use the stage 8 locking header bolts.
    If you feel like it isn't the header on the head, check the collectors. Sometimes with collectors when you torque on the engine the collector will separate some and get loud. As far as the rest of the system we always use muffler cement on every seam. Works great and never have problems.
  8. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Is it leaking from the head area or collector/exhaust pipe area? If by the heads, I ended up having to double the gasket on one side. The only thing I could do to stop leaking was using 2 thick Mr. Gasket header gaskets. High temp and Copper would still leak. Also you must constantly check and tighten the bolts on headers. If you use a gasket sealer use the copper stuff. Tighten the bolts, let the engine get warm and cool then retighten your bolts.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ditch the silicone, cut the flanges on either side of the 2 center ports, and you shouldnt have a problem.
    O cut here O O cut here O
    also, what are you using for bolts?
  10. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    My ramhorn manifolds were cracked so I picked up some used regular ones and some new gaskets.
    That was in 93 and I have not touched them since :D
    I think the longest lasting fix is manifolds :p:
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    What BeaterK20 said has always worked for me with headers and SBC. And other engines for that matter. and Felpro gaskets.
  12. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Stick a hose in your ear and start pointing it at crap. :dunno: Kind of stethoscopic in a way...
  13. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    I am using bolts with 7/16th head and an allen wrench hole in the head as well. I will go ahead and try to cut the flange and use manifold gaskets with no silicone. Thanks for the help.
  14. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    And if your still having probs, PM me and your welcome to swing by my place off Rita Rd. And I'll give you a hand ( or at least a beer )
  15. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Is 'stethoscopic' really a word?
  16. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yes it is.:D Though I may or may not have known it at the time...:whistle:
  17. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Over torqued?? All you need is 15-20 Ft. LBS..
  18. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    hey man sorry to hear your having problems. my boss has a 4 wheel drive 79 dodge truck with a 440 and he had this same problem. after many gaskets, tubes of hi temp he found out that whenever he really stomped on it the motor toqured so much that one header would hit the frame!! so he put a chain on the motor mount and new gaskets and he fixed it!! also to tell where a leak is coming from look in the general area the leak is coming from and look for carbon build up. a leak that has been there for any amount of time will leave quite a mark. also if you don't see any black run your hand over the exaust about an inch away with the engine running and when you hit the leak you will feel air blowing on your hand be carful don't burn yourself. its best to do this on a cold engine. good luck let us know what fixes it!
  19. YELL78
    YELL78 Registered Member
    Feb 27, 2005
    54
    ALBUQUERQUE
    dude make sure after you change the gaskets that you warm the motor and then re torque the bolts thats what i have done with all my stufff and i also use MR. gasket ultraseal gaskets i never have leaks oh yea i have hooker headers also.
