"Exhausting" education
Discussion in 'The Garage' started by justwhatido, Jun 27, 2004.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    \"Exhausting\" education
    I'm installing Jeg's GM 350. Will put on new exhaust. I've been reading posts about exhausts systems and have questions.
    Headers? Ceramic coated? Painted? or stock exhaust manifold?
    Exhaust: dual or single? what diameter gives what result? I thought that the goal was the least back pressure and it seemed that dual 3" would accomplish that. But I've read posts that indicate it would be detrimental. You guys have been in this for a while, so how about some input?
    /forums/images/graemlins/pimp1.gif
    Fred
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Re: \"Exhausting\" education
    On headers, ceramic coated will last the longest and look the best. The painted ones, the paint will flake off probably the first time you fire it up. However since you say you are putting a new motor in, if you pay the $$ for ceramic coated, you need to do the breakin with a set of stock manifolds or old set of headers because the heat generated during initial breakin will screw up the ceramic coating.
    Exhaust, I like duals, dont really know why, but a dual system w/ 2.25 or 2.5" pipe is good, I run the 2.5 on my bbc, but i also had it on my sbc. If you go single you have less crap in the way under the truck, and if you go single I would say a 3" would suffice.
  3. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    i don't know about others here, but on my truck when i opened up the exhaust the top end grew(by this i mean the beast loved to rev it up). the down side is i lost the back pressure and now the low end is lacking. it's all cause and effect. take from here to give to there. do you need the torque or can you spare a little for a quicker rev. also on my tbi i noticed that with out proper back pressure it didn't want to idle well, so you may want to factor that in too.
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The header quetion is answered. As far as single or dual exhaust, a 3" single will give you similar performance to a 2.25/2.5" set of duals. Unless you're running an extremely powerful small block, 2.5" dual exhaust is the absolute largest you should go. Any larger and performance will be lacking. I am running a set of 2.25" duals, and couldn't be happier.
    John
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Try-y ceramic coated headers and no bigger than 2.5" pipe. IMO best setup for a slow wheelin' machine.......
  6. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I would stick with small tube headers unless your running big expensive free flowing heads. Sounds like your going to use stock heads, so 1 5/8 is plenty enough for the header tubes. Personally I would go with a single exhaust (3" minmium), I think it sounds better, but dual exhaust is easyer and 2.5" is enough.
    As far formulas, to get optimal exhaust velocity, 1 5/8 is the recommended size for a stockish 350.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't forget an H pipe, it makes the rig sound so much better!
