Exhausting questions 89k-5
Discussion in 'The Garage' started by Jonny-K5, Jun 8, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i want to replace my muffler and cat with something that flows/sounds better. Problem is it has to be CA smog friendly, any ideas? i was thinking of a flowmaster muffler, not sure if they have a hi flow cat.
    question 2: has anyone needed to redo their crossover tube with a 3 in lift? the one that goes under the front driveshaft?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Flowmaster just sells mufflers. Dynomax sells the high-flow cat. I left on my stock cat but got them to put a Flowmaster 40 series single 3" inlet/ dual 2.5" outlet muffler on mine and bent new pipe for side outlet behind the rear wheels. Sounds great, some seat in pants power differance.
    Your Y pipe (That's the pipe your talking about...) will be just fine with a 3" lift. It's the 6" lifts you sometimes have to worry about.
