Exo and interior cage
Discussion in 'The Garage' started by shaun, Jun 21, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    If you have an exo cage what is the point of an interior roll cage./ Isnt that just alot of weight you could get rid of. What are the benefits to having an interior roll cage if you have an exo?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    an exo does almost nothing for support in a roll, just for looks.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Just for looks my ass! A properly designed exo can do alot more than just look like a jungle gym. First of all the point of an exo cage is to protect the body, that is it's primary goal. If you want good roll protection then you either need to cut through the roof and run an X brace behind the front seats for some triangulation or do a seperate inner cage and tie the two together. If you don't care about the body then just do the inner.
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    speaking of exo's Jason, was that what i saw on the crewcab? If so when did that happen? /forums/images/graemlins/ears.gif
  5. Grim-Reaper
    7,385
    Atlanta
    Needs a little cross bracing through the body but if done right it will protect the body and people. K% with it's narrow frame is actually pretty easy to cross brace through. If you give up the center consol iyou could brace down to the frame and rear seat passengers could pass between the front seets to gain rear access rather easily.
    Behind the back seat do a second cross brace and you would have a pretty tough Exo.
  6. shaun
    Apr 22, 2003
    745
    Thank you for the replies. I was just wondering. I was going to do a roll cage but since I also want to keep my body straight so I was going to do an exo. Just wonderin if it was worth doing an interior cage also.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You could do a combination of the two. I run an interior cage with lower body protection all around.
  8. shaun
    Apr 22, 2003
    745
    I was thinking a interior with cues off of dblazers when it was full bodied.
