exo cage
Discussion in 'The Garage' started by surpip, Jan 4, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    how do you do it with out connecting it to the frame? Where do you tie it to the body at? Ill have 4X4 iron rockers so on the sides im set, but what about the front and rear?
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i would mount it between the body and the body mounts if it where me but i realy couldnt tell you frome there
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    attach it to the bumper in the front, then at the rear go all the way back to the rear bumper, or just extend a mount from the frame, and weld it to the mount.
    Exo cages dont tie into the body, they go around the exterior of the body;hence, why its called exo. If you were to tie solid tubing into sheetmetal the sheetmetal would most likly stretched or crack.
    From what I can see you will have to attach it to the frame, whether by welding, or welding a plate to the tubing, then bolting the plate to the frame. Or you could built mounts simular to body mounts, but extend wider and weld them to that. It has to attach to the frame somehow to be sturdy enough.
    A few weeks ago there was an exo cage thread, look at the pics to see how it goes together.
    Good luck Dale!
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    welll, i dont want to tie it to the frame, thats why i asked "any ideas on where to tie it to the body?"
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay sorry my mistake:(
    Maybe someone more mechanically inclined can pipe up. I can't figure out how to attach it to the body... :o
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Wherever you attach it to the body, make sure you use a big plate on both sides to make sure you don't tear through the sheet metal.
