Experience with Detroit fronts
Discussion in 'The Garage' started by trailblazr81, Mar 13, 2007.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Im thinking of going the detroit locker route with the front of my K20. The rear k20 is locked, and I put manual hubs in front. Now Ive never locked a front axle before so I would like some input from those who have done it. First off this is not a DD. I use it to go to dump, boneyard, parts store, and wheel. I mainly do the trails, mud, sand, and maybe a little snow up in the mountains in the winter. On the street I hae rarelly noticed a rear locker unless I gun it in a turn. Now Im thinking it should be fine in 2wd with hubs unlocked and in 4wd the locker should allow tires to turn at different speed while turning unless Im getting on it. Detroit lists the locker as having:
    Smooth operation - even in front drive steering axles.
    Whadya think?? :confused:
  2. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    High speed detroit front 4wd and snow is DANGEROUS :wink1:
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    In 2wd you cant notice the detroit front
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    d60 or 10b/44? ive got one in my 60 and i love it!
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Mines a 44HD. I keep an eye out for 60's at the boneyards.
    And I understand front lockers are No Bueno on icy slush covered roads but why bad in snow? I would think it would be great for deep snow trail runs.
  6. user
    user Registered Member
    Mar 13, 2007
    73
    New Baltimore, Virginia
    I've been doing a lot of reading about that, lately, 'cause I'm upgrading mine, too. I've selected the Eaton Detroit Truetrac and am avoiding lockers entirely. I don't want to have to deal with the changes in steering and use of the gas pedal. If you aren't really familiar with how those things affect the truck before you get into slippery conditions, my impression is that you will definitely wreck the truck. four wheel drive isn't the same as four wheel stop, especially on ice & snow.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine is welded and it was 90+ here today. Offroad mine is great but I cannot run with slugs or hubs locked on the street as it will not unlock like a detroit.
    I have no experience with ice or snow (see above) but if I had the money I would go detroit in the front in a heartbeat:D
    Ira
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I believe the previous post meant that a front Detroit is bad for running down the highway when there is snow on it. Yes, for deep snow it is a lot better than an open diff.
    I've ran several different trucks with open, limited slip, and locked front axles and for on slick snowy roads I definitely prefer an open front diff. For off-road then definitely a locker.
  9. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    For your use i think a locker is an appropriate choice. With the hubs unlocked it won't affect operation of the truck at all. The diff itself will be stronger with the detroit than with a drop in locker. You should probably carry spare shafts for your D44 and look into some upgrades if you plan to keep that axle.
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    with a detroit up front, it would be nice to have assist for ease of steering with it engaged. same if it was welded or had pretty much anything besides a limited slip
