Experts only
Discussion in 'The Garage' started by binjabr7, Jul 1, 2005.
  1. binjabr7
    binjabr7 Registered Member
    Jan 3, 2002
    14
    :confused: hi there
    any one cod tel me which hub replace my( 1994 ff 14bolt)hub to expect
    the rotor to do the rear disc brake conversion.
    if there is part no or any advice thanks .
    1994 /burb /454 /4x4 /2500
    8lug /14 /ff
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    all you have to do is get the drums off the hubs and put the rotors on the hubs
  3. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Ok, as soon as I am able to understand what you asking I might be able to help.... :confused:
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    X2 :confused:
  5. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    he has the pop off drum 14ff rear. he wants to convert to the disc rear but needs info on if the hubs will swap over from the old style rears with out problems. this is the best i can figure out and i would like to know also.
  6. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    Im going to try and translate....
    Can any one tell me which hub replaces my hub so it accepts
    the rotor, so that i can do the rear disc brake conversion.
    -->1994/burb/454/4x4/2500/8lug/14bff
  7. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    "I'm not an expert, but I play one on TV"
    Your just asking for it with your post title :D.
  8. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    lmao..it took me afew times to understand it, but i got it...
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  10. binjabr7
    Jan 3, 2002
    14
    my god is that what i did to y,ll forgive me guys for that dilemma
    it is gust that i want to know which hub will fit on my spindle
    because my hub is not flat on backside to accept the rotor :bow: :bow: :bow: thanks
  11. divorced
    Jul 20, 2004
    5,115
    Here is a picture of mine, it's a 1977 model 14 bolt. The rotor fits on the backside of the hub after the drum is removed. Maybe something changed for the 1994 models? I haven't messed with any newer 14 bolts to know.
  12. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    haha i found this very funny :haha:
  13. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Press out your studs and seperate your drum from your hub. Use a 3/4 ton rotor, place it exactly where your drum was and press the studs back into place. Voila, no new hub is necessary for the conversion.
  14. divorced
    Jul 20, 2004
    5,115
    He has a '94 though, which is a newer body style than what most of us have. The newer 14 bolts have a removable drum and the back of the hub is not machined like the old ones are. A rotor won't fit the back of the newer style hubs.
  15. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    :doah:
