expirience with fuel injection
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BobK, Oct 12, 2000.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Thinking of changing to fuel injection.I've got a 71 Blazer with a SBC 350.Any suggestions?
    [​IMG]<font color=green>BobK<font color=green>
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Holley makes a pretty good bolt on fuel injection system. it comes with everything you need . I know a few people who have put them on their trucks and they liked them better than a carb. Got a little better fuel mileage too.
    Check it out:Holley multi point injection
  3. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Yup Holley makes a good one. You could also check out Howell Engine Developments(they make custom stuff). I think Turbocity has some stuff too. www.turbocity.com
    good luck
    Go heavy or Go home[​IMG]
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    TPI - factory GM parts with a Painless Wiring harness and it works like a charm..........lots of upgrades available depending on your budget. Easy install IF you get all the important hard parts off donor vehicle (Firebird, Camaro, Caprice, Impala, etc.).
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>http:// www.blazzinor.coloradok5.com
  5. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    If it's a stock 350, swap on a TPI or throttle-body system. This is actually a cheap way to go (for EFI). There is nothing wrong with a TBI from a 1987-1993 350 truck. You should buy a swapping book and go for it!
    I would not go with an aftermarket system on a stock 350.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Going with factory parts out of the junkyard is usually a lot cheaper than the aftermarket setups like Holleys, unless you are running big horsepower. A friend of mine recently converted the 350 in his Wrangler to fuel injection (TBI). He just bought an entire donor vehicle, pulled out the parts he needed and hooked them up to a Painless Wiring kit (after spending a couple of days trying to figure out the factory wiring harness), and then sold the donor vehicle to the junkyard. Total investment was under $300. I think the throttle body (TBI) is probably easier to do.
