explain foot pounds to me
Discussion in 'The Garage' started by tecton, Apr 3, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    it makes no sense to me at all
    what is a foot pound
  2. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    ft-lb is a measure of torque or twisting motion.
    1 ft-lb is the amount of twist you would have if you had a 12 inch wrench on a bolt and you put a 1 lb weight on the very end of the wrench.
  3. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    the amount of torque applied by that many pounds on a lever one foot long, or one pound on a lever that many feet long, or any combination thereof.
    So for 100 ft-lbs, you could put 10# on a 10 foot lever, or 100# on a 1' lever, or 1# on a 100' lever, which in theory should all apply the same torque.
    This is why if you can't yank off a lug nut, say, you get a cheater pipe, which gets you a longer lever for you to jump and down on.
    The scientific types will jump in and give you more details, but I think that's the basic idea.
    And is it foot pounds or pound feet? I always get it wrong.
    -- A
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have always had it explained as the amount of energy to move 1 pound 1 foot straight up i.e. lbs-ft. That is how you can calculate horsepower based solely on a torque number.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    that explains alot
    so lets say my truck makes 300lb ft or tourque...my truck puts 300lbs of force on the end of the hypothetical 12inch wrench?
    that cant be right
  6. dremu
    Feb 27, 2000
    15,967
    459
    Well, the engine might do 300 lb/ft at the flywheel -- if it's a big one, or a diesel -- but then the gear reductions of the tranny, transfercase and diffs increase that.
    So my stock 350 which puts out something like 250 lb/ft goes through the TH350 low gear which is what, ~3:1 and then the NP203 in low gear is 2:1 and my diffs are 3.73:1... so net is somehting like 5600lb/ft applied to the wheels. If I were flooring the poor girl in low/low in an ideal world of no loss, slippage, etc etc.
    This is why you can snap axle shafts /forums/images/graemlins/laugh.gif
    -- A
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    This just cracked me up when I read it /forums/images/graemlins/rotfl.gif
    I think it was the smiley that did it lol /forums/images/graemlins/histerical.gif
  8. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Nice
  9. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I think everyone pretty much covered it. An interesting tidbit- if you ever look at a torque/hp curve chart, they should always be equal (torque and horsepower) at 5252 rpm.
    mike
  10. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    New cat they are puttin in freightliners and kenworths
    How bout them foot pounds. For a truck engine at least, twin turbo. So now when they break people can pay $3,200 for new turbo's instead of 1,000.
    Cylinders In-Line 6
    Bore/Stroke 5.4 x 6.75 (137mm x 171mm)
    Displacement 15.2 L (928 cu in)
    Weight 2890 lb (1311 kg)
    Horsepower 435 to 550 @ 2100 rpm
    Torque 1350-1850 lb0ft @ 1200 rpm
    All for more power & Higher emissions standards /forums/images/graemlins/rolleyes.gif
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    15.2 L /forums/images/graemlins/yikes.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/eek.gif
  12. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    I drive a truck with 500HP and about 1500ft/lbs /forums/images/graemlins/laugh.gif
    Coming out of a Detroit 60 Series turbo, with a 3 level engine brake.
    Really makes me want to buy turbo diesel pick-up.
  13. mogas
    mogas 1/2 ton status
    Apr 5, 2004
    118
    Flagstaff, AZ
