explain shackle flip
Discussion in 'OffRoad Design' started by lowharley, Mar 19, 2003.
  1. lowharley
    lowharley Registered Member
    Feb 18, 2003
    20
    I see how the shakle flip can help with axle wrap by decreasing the need for lift blocks, but how does a shackle flip improve articulation?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Only by letting you run a flatter, softer, spring. Otherwise you don't get any appreciable gain. There are some handling differences between a flat soft spring and a heavily arched soft spring and typically the flatter spring handles better. That's about it. No pixie dust involved.
  3. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Are the 2.5" and 4" kits the same as far as flex. I'm guessing the 4" kit just puts the mount lower relative to the frame?
    The reason I'm asking is I'm trying to decide between 4" springs and 2.5" flip or 2.5" springs and 4" flip. /forums/images/graemlins/thumb.gif
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We always recommend the taller flip and shorter spring. In most cases, the shorter the arch, the easier they move. The only time I would go the other route is if it was going to be a buggy or bobbed rig where the shackle would end up the last ditch ground clearance point, then the shorter flip and taller spring might be worth the little gain in departure angle. On a regular full body vehicle, departure angle is set by other points and the 4" is the way to go.
  5. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    I am thinking of BDS or other brand 2.5" Springs in the front and a 2.5" Shackle flip with a Zero-Rate in the rear to increase my articulation. I am running completely stock on 32s and I will keep those until they run down. Will this give me 2.5" of travel of more? I think 2.5" is right for me since 4" would create problems getting into garages here in the city...But maybe I am wrong? Any advice? I want better trail performance without going to BIG tires...33" is probably the max unfortunately.
    Brady
    Brady
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Thats similar to what im thinking. Im running 33's, want to go to the BDS 3" and am wondering if going to a 4" shackle flip with stock springs is whats needed to make it level and not sag too bad when loaded. Whats the thoughts?
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Sounds like you guys need to check out our "burly 'burb" project. It's built right along the lines of what you're talking about. 3" fronts, 4" flip in the rear and since it's a 'burb, it has a rear zero rate too. It worked really well with 33's and with some trimming 35's are OK.
  8. BJarvis354
    Jun 17, 2002
    58
    New York City
    Well, that sounds like the right plan...But you know how lifts go, 4 inch springs might be more like 5" in reality! It sounds like the ORD flip is a true 4" though. But I am going to add 1" zero-rates just to be sure my rear isn't saggy.
    Brady
