explain something for me
Discussion in 'The Garage' started by tecton, May 5, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Timing
    what is it
    what does it do
    what does it do if its off
    what does it affect
    mmmm yeah
    (dont get mad, im just trying to learn)
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    makes the electrical spark to the correct chamber at the right time... /forums/images/graemlins/thumb.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if its off, your motor can "ping" it can back fire through the carb, it can "Diesel" when you shut it off, dieseling = when you turn the car off it still wants to run....
    im pretty sure if your engine "pings" for awhile that it can actually blow a hole in the piston,
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It also gives you better fuel economy and power, when it advances, via, the vaccuum advance.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    What is it? - It's the way the distributor is set to send the electrical charge through the spark plug wires to the spark plugs.
    WHat does it do? - See above. When correctly set the spark plug ignites the gas in the cylinder while the piston is at the top of the cylinder.
    What does it do if it's off?- If it's not set right, there's a lot of different ways the motor will react. They include pinging, run-on(dieseling), hard starts, lack of power, and more.
    What does it affect?- Basically, if your timing is off your engine will not work like it should. There are four stages of combustion:
    Suck- The intake valve opens. The gas is pulled into the motor as the piston drops into the cylinder.
    Squeeze- The intake valve closes. The gas/air mixture is compressed as the piston travels upwards in the cylinder.
    Bang- The now-compressed gas/air mixture is ignited by the spark plug, forcing the piston downwards.
    Blow- The burnt gas/air mixture is pushed out of the cylinder as the piston goes up again and the exhaust valve opens to allow it out of the cylinder.
    If your engine isn't banging when it's supposed to, it screws things up!!!!
    Hope this helps, brother.
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well there are two kinds of timing...valvetrain timing (when the valves open in relation to crank rotation) and spark timing(when a spark ignites the air/fuel mixture in a given cylinder, also measured in degrees of crank rotation)
    Most of the time, when people talk about timing, they are talking about spark timing...Valvetrain timing is usually within 4-degrees of TDC (Top Dead center)of the number one cylinder.
    Spark timing is an interesting beast. Thespark must ignite the air/fuel mixture at the right moment..too early, and you have pre-ignition (also called detonation) when the air/fuel mixture is ignited when the piston is still on its upward compression stroke..this tries to push the piston down even though it want to continue traveling up.
    If the spark ignites too late, you lose valuable compression of the air/fuel mixture and loose potential power...
    Ideally, at idle, the plug will spark just before or AS the piston reached the top of its compression stroke (the top of the compression stroke is also called TDC)
    You set your timing by rotating your distributor. A timing light is used identify where the spark occurs in terms of crankshaft rotation. On my TBI 350, at idle, I have 0-degrees of advance. This means that when the number one cylinder is at the EXACT top of its compresion stroke, the spark occurs
    As with many things there is a catch...as the engine speeds up, the spark must occur sooner and sooner. This is because the spark takes a split second to ignite the air/fuel mixtue. As engine speeds increase, the plug must spark sooner and sooner so the actual combustion takes place when intended (just as the piston reaches TDC)...Therefore, the engine must have a way of Advancing the timing...newer, fuel injected engines use computer comtrolled distributors to advance the timing..Older engines use either vacuum advance or mechanical advance to advance the timing curve.
    Chris /forums/images/graemlins/thumb.gif
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    suck
    squeeze
    bang
    blow
    [/ QUOTE ] Hehehehehehe
  8. Can Can
    15,552
    136
    I learned that in high school auto class. For some reason I've never forgotten it........ /forums/images/graemlins/wink.gif
  9. chevyfumes
    Feb 24, 2000
    38,584
    266
    Your teacher made you do bad things and that is wrong, you may have a lawsuit..... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  10. Can Can
    15,552
    136
    But she had such a sweet ass- how could that be wrong??? /forums/images/graemlins/confused.gif
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
  12. tecton
    Dec 1, 2002
    1,553
    WV
    helps alot, thank you
    someone said my truck was "spark knocking"
  13. Grim-Reaper
    7,385
    Atlanta
    Several things can cause spark knock. Timing being to far advanced is the big one.. Carboned up valves and combustion chambers, cloged air filters causing the fuel mixture to be lean. Fuel delivery problems cause lean fuel mix, stale fuel, Fuel of to low of octan for the compression ratio.
    You truck if stock should do ok on regular but you might want to run some mid grade through it and see if the problem get's better.
    Now I recomend you do get a shop manual. your truck should have a ESC distributor with a knock sensor. If I'm correct then the Distributor ECU located behind the glove box should be backing off the timing to prevent "Spark knock". For what ever reason it's not doing it. Could be a bad knock sensor or it could be a electronic problem with the Distributor or distributor ECU. It is something you really need to repair because you can cause damage to the engine if it does this often.
  14. tecton
    Dec 1, 2002
    1,553
    WV
    the guy i bought the truck off of built it up
    my dad said if its cammed that i need to run 92-93 octane....it does idle better with higher octane
    but it will do it when i start it up after its been there a while...it will do it, ill hear like...almost like someone shotting an air gun...then itll run fine til i let it set again
