Explain velocity stack???
Discussion in 'The Garage' started by 85mudblazin, Sep 19, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    How does it work and what kind of performance gains is there??
    -Chris
  2. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    282
    156
    Gustine
    Re: Explain velocity stacked???
    A minor correction of terms. It's not velocity stacked, like pancakes or women's breasts, but velocity stack, like a smoke stack. Typical set-up is designed to allow clean, non turbulent air into a carb or fi inlet. By adusting length, they can be tuned to specific engine rpm use.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow ok velocity stack, I was just watching top truck challenge and toby's blazer had it.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    2003 TTC?
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yup /forums/images/graemlins/thumb.gif
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay cool
    where does it mention velocity stack?
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Dont mean to go off topic but I just bought the TTC 2003 on saturday and I have seen it atleast 6 times already. There are some freakin crazy wicked bad trucks in there!
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Isn't it just a throttle body spacer designed to create more turbulence and therefore more atomization of fuel= more power? /forums/images/graemlins/smirk.gif
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    He says it when they are going over each truck and they are looking at the engine is his blazer. /forums/images/graemlins/thumb.gif
  10. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
  11. RustBuket
    Feb 21, 2003
    1,618
    Oh ok, I was thinking of something else. Yes, those are used to tune an engine so that at a certain RPM you will get an almost supercharger like effect. /forums/images/graemlins/cool.gif
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so do they work and would it be good for offroading??
  13. RustBuket
    Feb 21, 2003
    1,618
    They wouldn't be any good for off roading because I don't think you can run a filter if you run stacks.
    The incoming air hits the closed intake valve at a high velocity so the air "crams" into a small space and creates pressure. Then the pressure build forces the air back out again creating a vaccuum zone. The trick is to make your stack the exact length so that when the intake is opening again the air is rushing into the low pressure area creating the supercharger effect. There is a formula to determine the exact length but I have forgotten. I read it a long time ago in a Hot Rod article. /forums/images/graemlins/thumb.gif
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    not sure about the filter but, toby had a filter atop his /forums/images/graemlins/screwy.gif
  15. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    really popular in the 70's if memory serves me...
    you can filter them to a certain extent.... thin foam filter that gets sandwiched between 2 screens at the top...
    had one on my 340 Duster, seemed to work pretty well...
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    it cant really hurt anything right?? I mean for 20 bucks if it improved anything it would be worth it. /forums/images/graemlins/whistling.gif
  17. RustBuket
    Feb 21, 2003
    1,618
    BUT if you have to run a POS filter and then end up wearing out your engine quicker than you have to then thats no good either. /forums/images/graemlins/blush.gif
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea your right I am just going to save myself a headache on this one /forums/images/graemlins/thumb.gif
    thanks for the info though
  19. RustBuket
    Feb 21, 2003
    1,618
  20. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have a Velocity stack on my TBI Blazer. I used it to get rid of the air choking POS spacer that goes between the air cleaner housing and the TB. Got more air flow. I have a lot better throttle responce.
    I cut a bigger hole out the bottom of stock air cleaner housing to fit the diamater of the stack. And riveted it to the bottom of the housing. Works great.
    Velocity stacks help to speed up the air flow at low RPMs
