exploer.exe taking up 99% of cpu? HELP!**STILL MESSING UP**
Discussion in 'The Lounge' started by y5mgisi, Feb 24, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    So my comp as been running extra super super way slow, I do ctrl alt delete and it brings up the prosses screen and it says that explorer.exe is using 97%-99% of the cpu. So it was ok for about a week... I do the spybot S&D again and get 10 things removed but it dosnt help at all... So before i have to see if mudhog wants to be put through hell with this thing still id like to geive it one more shot... So i did a print screen of my prosses page deal and BTW i have 50 or so prosses going on at all times is that normal? Here it is do you notice anything out of the ordinary? Also when i try to run sweepi it just freezes on temporery files.:confused:
    Damit the pic didnt work hold on let me see if i can fix it. well that dosnt work out very well iether...Now you can see just how computer savey i am and just why i might be having trouble with somthing more coplex then even posting this damn pic.
      File size:
      292.6 KB
  2. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    wow, im not the only one?? well i cant help you, but mine does that approx 2-3 times a week, and all i can do is restart it and go as normal until the next time it does it.. good luck, please let me know if you find a cure..
  3. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Run adaware then spybot S&D. It will fix your problem.
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    First you gotta take a shot of Jack to numb the pain. ;)
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    :waytogo: Now that's good advice.:bow:
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    dont take it in and have it done bring it over to me and ill show you how to do it yourself:D
  8. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Complete with whiskey? ;)
  9. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    soyware cleaning 101
    1 - Whisky (jagged is right about this, this may be boring and frustrating)
    2- install and update the following FREE software.
    a- spybot (www.spybot.info)
    b- ms antispyware
    c- spyware blaster
    d- cwshredder
    e- sweepi (google this one)
    3- boot to safemode (reboot and start hitting f8 as fast as you can until you see the menu for safemode
    4- run spyboy scan, remove anything it finds.
    5- run MS-Antispyware scan, remove anything it finds
    6- run sweepi and let it do a full cleanup (this will clean the spots the spyware hides its re-installation tools
    7- run spybot again, and use the immunize tool
  10. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    You should also go to http://update.microsoft.com and install updates. You may have a quirk issue.
    Quick MS KB search (doesn't sound applicable to you, but worth a read):
  11. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    good stuff thanks for the replies guys. Im going to try a couple things first and if i cant get er figured out i'll hold mudhog to his offer.
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem im almost always home lol
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    mine is doing the same thing. i run spybot, avg, and adaware every few days, as well as clean up. i defrag about every 2 weeks. still been having the same problems. the only thing that i havent done, is install the latest updates for windows. when i do that, it says that it needs to install service pack 2. i did that once before, and it really fubared my machine. have they since fixed sp2? i'm in the process right now of removing all of my files from my main drive (pics, vids, music, etc.) and putting them on my secondary. probably going to wipe out the whole system and start all over again pretty soon. unless i can find a fix for my problem.
  14. CustomChevy
    Jun 29, 2005
    4,328
    uhm, there is nothing wrong with sp2. the only way i could see it killing you windows is if you already had major problems.
    make sure u clean up before sp2!
