Ext Brake Line Info
Discussion in 'The Garage' started by BurbLover, Aug 6, 2005.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    EDIT: Okay, thanks to Divorced, I found the link I needed and one of the part #s I needed.
    What part # are you using for an extended brake line for the rear axle? If you got it from another vehicle, what worked for you?
    TIA!!
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks. Got the coversion joint info, but can't find the brake line info.
  4. divorced
    Jul 20, 2004
    5,115
    I used a longer braided stainless line on the rear of mine.
    How much longer do you need? Maybe you could lower the bracket and hardline and use a stock hose?
    From another post someone said that Napa #4138068 is a longer rear line. If your local napa has one in stock you can check it out.
    :D
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks man!! You've been a HUGE help with this. Hopefully I can return the favor sometime :waytogo:
