Extended Brake Line For K20 ?????
Discussion in 'The Garage' started by Rolled, Oct 8, 2006.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I am getting ready to replace my brake system in my 82 K20. It is a daily driver so no lift but I may give it a small lift down the road.
    Since I may get a lift on it someday, I want to go ahead now and get longer lines. makes sense, right :) 2" to 4" lift would be the possibilities...
    What off the shelf part numbers do you know of? Or what other applications have a brake line that will work but are longer than the k20?
    My K20 is the 8600 GVW version so the braking is suppose to be different. The rears are 13 X 2.5 and I think the fronts may have a different calliper. Don't know for sure but it may make a difference.
  2. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    go to www.skyjacker.com. you'll need an fbl27 IIRC i put a 6 " lift on my k10 using 3/4 ton axles and used fbl29. they're around 100.00.
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    just contact shane74 - he's got a great product and can make whatever you need regarding brake lines. :) check here for his info. i have a set of his lines and couldn't be happier.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    NAPA 38872.
    15.00 each.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    X2.
