extended brake line modification
Discussion in 'The Garage' started by 78Suburban, Jul 14, 2006.
what do I do with my 10mm lines and 7/16 calipers?
  1. drill lines to 7/16
    46.7%
  2. sell lines on ck5, and get the correct ones (specify part nubmer)
    20.0%
  3. I don't know, but I'm NEKKKKKKKIDDDD
    33.3%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I got some extended brake lines for my burb for next to nothing. They are IFS brake lines, but I think they're actually designed for the 10mm bolt (what I was thinking I had). When I went to put them on today, they bolted right up to the hardline inside the chassis, but when I took the caliper bolt of, it turned out to be 7/16". Can I drill out my extended brake lines to 7/16, or do I just need to dig up a napa part number and go get a different set?
    thanks,
    James
    PS: I can post up pics of the lines if that would help.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    With something as critical as brakes, I would rather have the peace of mind and get the right parts.
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Heres a picture of the brake lines I bought
    so if these can't be modifided for a 7/16 bolt, what part number do I need for my '78 corp 10?
    Its odd that they screw into the hardlines inside the chassis fine.
    thanks,
    James
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I drilled out mine I got from a guy who had them on a Dodge pickup basically drill straight and use a new bit to prevent them from getting chewed up. The only thing you have to worry about is making sure there is enough meat left to seal to the brass washers, those are what seal everything up. If there is any doubt about reliability I have run these brake lines for 3 years now
  5. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    mine were tight too, the bolt wouldnt fit, i drilled mine and have had no worries
  6. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    I drilled out mine for my '76 blazer, they have worked fine (zero leaks) for about 3 years now. It will be a LOT easier to drill the hole straight if you use a drill press and clamp the fitting down to the drill's platform.
  7. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah, on a Banjo fitting, the crush washer does the sealing.
    As far as custom lines, I would think any shop that can make power steering hoses, ought to be able to make-up brake lines.:D
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    or you could contact shane74 who sells really great conversion brakelines.
    :wink1: (blackwidow performance)
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    as soon as I get some spare time, I'll give drilling them a shot and see what happens.. hopefully I won't FUBAR that copper washer.
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    go buy the right size copper washer
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    yup
  12. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm a little scared I will FUBAR these lines AND have to buy a new set of lines, when I could just sell these more than likely. How much do the Napa extended 7/16 lines run?
  13. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    just drill them, I have drilled a couple sets on various trucks already. Put the end in a vise so it doesn't move but don't crush it either then just drill. Get the right washers though.
  14. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    and blow them out from the other end.
  15. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Good call, go from the opposite end so you don't blow shavings down the line. It's the top and bottom mating surfaces that are the most important. The hole itself isn't as critical. Go down and get some 7/16 crush washers, and you should be good to go.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :waytogo:
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    ok, so I'll need to get some 7/16 copper crush washers if Im understanding right. One for the front and one for the back of the fitting. And I'll take the old copper washers out...
    So where does one get a copper crush washer, and what does it look like (just like whats pressed into the line already I assume??)
    thanks,
    James
  18. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    parts stores will have them, prob the easiest thing would be to take your banjo bolt that fits the calaper in with ya and get the copper washers that fit it.
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    BINGO. Just ask for the application the 7/16 fit.:D
  20. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    copper washers???
    I'm a little confused as to what I'm supposed to do about these copper washers i'm supposed to use... I didn't see any copper washers on the extended brake lines I bought, or on the brake lines I took off. I think I noticed copper washers pressed into the calipers and onto the bolt that screws into the caliper. Am I supossed to take the washers off the bolt and caliper and replace them?? Why if they're already the correct size? Are they a one time use kinda thing?
