extended brake lines for a 14B-FF (did a long search!!!!!!)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Langosta39, Feb 4, 2003.
  1. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Ok,
    To avoid digging up a dead thread I searched all the posts I could about parts store extended brake lines and I found a couple numbers for 4" lift rear lines, but nobody says that they have a 14BFF rear end. Now I could be wrong but I believe the block connectors are different on the big axle vs. 10 or 12 bolts. SO, does anyone know of a parts store number for 4" lift brake lines that will work with a 14 bolt FF?
    Thanks, and sorry for bringing up old topics if I missed the answer in my search.
    andy
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: extended brake lines for a 14B-FF
    The blocks are the same. When I did my swap to 14B/D60 I purchased ProComp SS lines for a Chevy/GMC, everything fit without a problem. /forums/images/graemlins/thumb.gif
  3. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    Yep, the block is the same and the lines screw right in.
