extended brake lines for a 4" lift ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Aug 19, 2002.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    extended brake lines for a 4\" lift ?
    i have already ordered my 4" rough country lift
    with blocks in the rear.
    i have a 84 k5 blazer,i want to be prepared when i
    go to install this, so i need to know if i need
    extended brake lines , and where do i get them?
    i guess my driveshafts should be ok as long as i
    swap the t-case spacers ?
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Re: extended brake lines for a 4\" lift ?
    Check HERE .
  3. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I was fine with just a 4" lift, but if have a lot of articulation it's not a bad idea. Once I put a 2.5" add-a-leaf on the brakeline was stretched beyond capacity so I got new ones from Pro-comp. You can order them at 4wheelparts.com about 90$
  4. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    4 WheelParts has them for around the 90 dollar range for stainless set, includes front and rear. That's cheaper than stock length rubber hoses from NAPA. They have great service too. That is where I got mine.
