Extended Brake lines with 4"s?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Apr 11, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Extended Brake lines with 4\"s?
    I got a 76 K10 with a 4"suspension lift. Would it be a good idea to get extended brake lines? Or should I not worry about it. I havent had any problems yet. Thanks for your input.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: Extended Brake lines with 4\"s?
    You could get away without them, but if you start to improve the flex on your truck (or has happened before you purchased it), then you'll want to get extended lines.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I would put the lines on your "future parts" list. I just changed mine (my rubber ones were starting to get little cracks in them.) I'm running 2.5" lift and went with the 4 inch lines.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    my rubbere ones were stretched on my jimmy qwith 4 inches and 35's...
    Putem on your futer parts list, if not sooner if there stretching...
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Also depending on how well it flexs you may need to go longer than the 4" extended lines. I run the longest lines Super Lift makes. They are for their 12" lift. Never had a problem with them, but did have a problem with the ones that were for a 4" lift.
  6. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    "my rubbere ones were stretched on my jimmy qwith 4 inches "
    hahahahahaha sorry
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    LMFAO!!!!! HAHAHA!! Good one dude...I didn't even catch that one. /forums/images/icons/smile.gif
  8. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I've got a 4" lift and I went ahead and put on the superlift 12" extensions. I plan on getting more flex in the future and I didnt want to replace my lines again so I bought the longest available. I also have dropdown brackets on them that give me another 4"s
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My lines were just lowered at the frame point w/ some drop brackets welded to the frame when I got it. I put on the 4-6" procomp lines and left them in the drop down brackets (which drop them down around 3")...plenty of slack now.
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    do you have poblems with them snagging on stuff? that seems like a whole lotta sloack to be flopping about in a wheel well...
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yep, you'll definitely want some longer brake lines. ProComp stainless ones are purdy nice, thats what I use on my rig. The kit I got is supposed to be for 4-6" of lift... so it gives me some leeway (since I have around 5" of lift) and allows for a good amount of flex.
    J
  12. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    I have a 2" lift in the front and my stock lines start binding way before my truck would stop flexing... I got some lines for a 6" coming..
