Extended brake lines?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kilomanjaro, Jun 28, 2001.
  1. kilomanjaro
    kilomanjaro 1/2 ton status
    Feb 22, 2000
    229
    Manhattan, Ks USA
    I just bought another blazer, it has a rancho 4" lift on it. I am not very expierienced with lifts, so i am not sure if everything on it is done correctly. It has 33X12.5's on it, and i like them so i am going to leave them. Ok here is my question do i need extended brake lines with a 4" kit? Do i have to get longer driveshafts? Can the steering arm be slightly angled or must it be perfectly horizontal? If i end up having to replace too many parts i am going to go with a 2" lift. as i recall you can run 33's and a 2" lift without having to extend brake lines or make any other mods. any input would be great. thanks
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    You can move the brake line bracket down to the bottom of the frame and not have to buy new lines with 4" lift. I would not streach the driveshafts on a 4" lift but it can work but again not recomended. The steering arm/drag link must be level/parallel with the ground to operate correctly. You should have a raised steering arm installed to correct the angel of the draglink.
    Hope this helps...
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  3. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    A longer steering arm can be purchased at a local 4wheel shop for about $50-55
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I too have the 4" Rancho. I love it and I run 35s. Any questions you have, feel free to post them or email me and I'll be more than happy to help.
    Tim
