extended brake lines
Discussion in 'Suspension | Axle' started by muddybuddy, Aug 16, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    pair of rubber extended brake lines. i believe they are 25" long. worked well with up to 8" lift. only used for 1k miles.
    $30 + shipping
  2. gaspass
    gaspass 1/2 ton status
    Apr 24, 2004
    185
    Pocatello, Idaho
    Would they fit a 1st Gen? I was actually looking for some brake line relocation brackets, but if these would work....
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    depends on calipers used. 7/16 vs 10 mm banjo bolt
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    these are off an 88 k5 so its the newer style, 10mm i believe
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    nobody needs longer brake lines cheap?
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  8. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    PM sent...
  9. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    will these work on my 85 cucv with d60/14b combo?
    Remington
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    pm sent to loafer
    yes they should work. i had then hooked up to my '84 d60
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
