Extended brake lines
Discussion in 'The Garage' started by trukman1, Mar 28, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Does anyone have part numbers for extra length flex hoses for the Corp-14 bolt rear brake line and also for the Corp-10 bolt front brake lines? Looking to lengthen these lines but not sure which part/ make to ask for at parts store. I am currently running a 4" lift. Thanks in advance for any help. Gary
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i think the 14FF are the same as the 10/12 bolts. they were 3/16. I'll double check when i get home tonight. same for the front. I got the procomp ones, i'll check the part number too.
    ARQ.
  3. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I am a big fan of ProComp stainless brake lines. I *think* the ProComp model number on mine (compat with the front 10-bolt + 4-6" of lift) is: 7220. Not 100% sure on that... but 4wpw sells them, and they'd know for sure...
    J
  4. trukman1
    Mar 5, 2002
    129
    Ohio
    Thanks Guys! Having this kind of information to go on sure makes it a lot easier to make changes...especially IMPORTANT things like brakes. Your input is appreciated. Gary
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Hey before you run out and buy the 4-6 brake lines. You might think about how you wheel and might consider a longer set in the front. For example I have a 4" lift and I'm running 12" Superlift extended brake lines in the front. Just a thought you might toss around.
