Extended flexible brake lines - secured to shock or ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Jul 28, 2003.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I need some ideas about securing my extended front brake lines so that they don’t rub against the tire. I have seen the lines secured to the frame with a spring, or secured to the shock body somehow. Any suggestions? How is the line tied to the shock to still allow movement of the brake line?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sure, if it's hooked up correctly.
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i used carb return springs on mine drilled a couple holes in the fenderwell works great,i had them attached to the shocks but the clampy things broke real quick,, /forums/images/graemlins/thumb.gif
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I used one of those zip ties with the hole in them so you can put a screw or other fastener through them around the shock where it doesn't move (the metal cover, not the body). I then put a regular zip tie through that little hole and around the brake hose loosely. This seems to work, I don't seen any abrasion on the hose. It doesn't hit the shock body or the tire so it does alright.
  5. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    I took the brake line relocation brackets from the lift kit (I wasn't going to use them anyway) and modified them. I shortened them and rounded the edges a little bit. Drilled a hole in one end and mounted it to the stud on the bump stop. The Procomp SS flex lines that I used came with some rubber hoops that I bolted to the end of the homemade brackets. Works great.
  6. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    If you havent already found a solution... you might just let them hang. They should have a built in curve to them, just rotate them so they stay away from the tire. Mine have been like this for almost 2 years. I didnt like the idea of tying them down cause that was gonna limit them.
