Extended Front brake lines ?
Discussion in 'The Garage' started by Mudbug1979, Jul 22, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Extended brake hoses that are 25 7/8" long will fit 10bolt from 89-2000 2wd chevy/gmc from right front but will work for both sides and can be modified to fit a D44.
    Part #'s:
    Napa - 38872
    Raybestos - 38872
    Auto Specialty - HB-86045
    Coni-Seal - BH-177767
    Carquest - SP8820
    Are these the ones that will fit on a 10bolt with 4" of lift? I think that these are the one's for the gm 2wd truck. Thanks, /forums/images/graemlins/waytogo.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, direct fit. Just goto the parts store and ask for the part number. 10 bolt is a direct bolt on, slight mod needed to make them fit D44 calipers /forums/images/graemlins/thumb.gif
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    What modification do you need to do to make them work on the Dana 44 disk brake setup?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    shorten the banjo bolt an 1/8" and ream out the banjo bolt hole end of the hose to fit the 7/16" banjo bolt. That is what I did with mine /forums/images/graemlins/thumb.gif
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    The ones that I bought are marginally longer, maybe 2 inches unless you bend the hard line going into the caliper. Also, there is no good way to mount it to the frame since the shape of the hole is different, so you have to rig it up instead of using the clip to hold it on. IMO, not a direct bolt in and not worth the minimal gain in length.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I used the clip to hold mine in place /forums/images/graemlins/thumb.gif
  7. BlueBlazer
    Feb 15, 2001
    1,940
    My one ton frame might be different as far as the shape of the hole in the frame. Mine had a hexagon shape to it while the line was round with one locating tab on it that would not allow it go sit in the hole in the frame.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Gimme a couple min and I'll get you a pic of mine /forums/images/graemlins/thumb.gif
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Can't really see the hole, but it is a hex hole and the hose part is round, I just used a stock clip and you can see /forums/images/graemlins/thumb.gif
  10. BlueBlazer
    Feb 15, 2001
    1,940
    The way you have it set up, that clip is not doing anything. The clip has to be on the back side of the frame to pull the hard part of the hose against the frame, thus stabilizing it and the hard line going into it.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The other side is solid, the hard line is fixed to the frame.....the hose does NOT move at the clip
  12. BlueBlazer
    Feb 15, 2001
    1,940
    Explain to me how that hose is affixed to the frame.
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    On the inside of the frame rail, I took the snap ring off the extended hose and put it on the hard line so that the snap ring and the c-clip hold it solid to the frame /forums/images/graemlins/thumb.gif
  14. BlueBlazer
    Feb 15, 2001
    1,940
    OK, that makes sense, still not what I consider to be "bolt in", but it works I guess.
  15. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Napa brake lines were a bolt in on my 85.
    -Chris
  16. BlueBlazer
    Feb 15, 2001
    1,940
    The end of the hose had a hex shape to it?
  17. sickquad
    Jul 23, 2003
    785
    Ma
    Now that I think about it, I am wrong. I had to just touch the fitting on the brake line to the grinder. Had to grind of barely any material before it fit in the hole real nice. I would still consider it a bolt in though.
    -Chris
