extended front shackles..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, May 25, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Can someone give me the pros and cons on using the extended front shackles, like the ones ORD sells. Are they necessary?
  2. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    A lot of times the stock front shackles allow the spring to hit the under side of the frame under compression. ORD's shackles are about 1/2" longer and prevent this from happening. They are also built from thicker plates than stock so they keep the axle located laterally much better than the stock ones. I would also spring for the greasable bolts and all at the same time. I found they increased travel and flex, improved the ride measurably and got rid of a lot of squeaks i had.
    HTH
    Rene
    <font color=red>If at first you don't succeed...skydiving ain't for you!</font color=red>
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    WOW!! advice from a living legend!! LOL! Thanks
  4. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    LOL...I'm baaaaack!
    Rene
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I didn't use the ORD parts but, I did notice a softer ride and more flex on mine. The ones I have are about 1 1/2 longer. I only did this much to make my tire stop hitting! But my pinion angle was affected.
    your right. I don't understand the jeep thing!
  6. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    bablazer73 - how bad was the pinion angle and how did you deal with it? What size lift are you runnin'
  7. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
  8. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I was running 4" front springs. Raised me up to 5". I never really had a problem with the front shaft/pinion angle. It never vibrated. I dont have unlocking hubs on my truck. Shaft turns all the time. But it looked nasty!! the pinion pointed down!
