extended parking brake cable brackets?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin_willy, Jan 24, 2003.
  1. wheelin_willy
    wheelin_willy Registered Member
    Jan 23, 2003
    24
    anyone now of a way to extend parking brake brackets on a 6" lift. buy or make /forums/images/graemlins/usaflag.gif
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    make em, it shouldnt take too much
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    on mine i took the factory backet, ground off the two rivets, then took two spring bushing sleeves and (for my 4" lift) cut about 1/4 of the length off and used the 3/4 length side and put a bolt through the middle of the sleeve into the frame and put a nut on the otehr end. FOr your 6" you might need the full length. Thats what i did and it worked.
    look over the spring and u can see the brake cable bracket.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I used something a little less high tech, I pulled the cable out and added a section of 1/2" pipe 2" long.
  5. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    If you want to consider getting longer parking brake cables instead, you might look for cables from a van. When I pulled my 14-bolt out of a van, I discovered that it had longer parking brake cables than the Blazer.
  6. ratpack_7
    ratpack_7 Registered Member
    Mar 24, 2007
    68
    Salt Lake City, Utah
    What year van?
  7. ratpack_7
    Mar 24, 2007
    68
    Ok... thru an extensive search and comparison. I think I have found the right length parking brake cables for my 72 with a 6" lift. with part numbers. It looks like the rear parking brake cables from a 1971-1975 G10 van is the right length.
    The rear cables for a 125 inch wheel base van is
    RAYBESTOS Part # BC92465 {46" Overall Length}
    and the rear cables for the 110 inch wheel base is
    RAYBESTOS Part # BC92918 {47 1/4" Overall Length}
    BTW the stock cables for a 72 Blazer are 40 1/2 inch overall length.
    I'm going to purchase them tomorrow and let you all know for sure that they work. From the images of the cable the ends on all 3 are the same.
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Any updates on the cables used and which worked?
