extended parking brake lines?
Discussion in 'The Garage' started by weisel, May 31, 2003.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Those of you with lifts or flexy suspentions, how did you maintain the parking brakes? Mine barley fit when the trucks level, but if flexed out there would be no way if would fit.
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I will be messing with this myself soon when i do a shackle flip and axle swap.....
    I've seen people basically lower the mount where the cable goes from uncovered to covered. Just take a strong piece of angle iron with two large holes in it. One on each end. Take the cable out of it's old mount...bolt the angle iron into that old cable hole and then run the cable into the lower hole of the angle iron....
    Cheap and it works from what i've seen. The down side to this is that it could be considered slightlybad ground clearance in that area....but i really don't see that being much of a problem...except if you were a hardcore rock crawler...but in that case, you probably don't have parking brake cables anyway...
    Blake
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh on my truck i just cut off the facotry rivets that hold the bracket up, used the metal sleeves that go into spring bushings, and ran a bolt through the factory bracket, through the sleeves, and then through the frame and put a nut on the back in this pic, look to the top right and you can see it
    For my truck since I only have a 4" lift i cut the sleeve in half, but if its a larger or flexy lift, use the whole sleeve.
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i cut the bottom hole and let the brake line go through it and hang, the line that goes to the rear passenger tire was fine, i suported the drivers side one with a spring. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
