Extended rear brake line?
Discussion in 'The Garage' started by bigchevy80, Mar 27, 2004.
  1. bigchevy80
    bigchevy80 Registered Member
    Aug 26, 2003
    40
    I need an extend rear brake line. The one that goes from the frame to the axel. My truck has a 4" lift, but i would like to maybe go bigger some day....SO were can i get one?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I bought the Pro Comp braided stainless extended hoses but the rear was the same length as the original. I ended up making a longer bracket from the differential mounting to the brake hose and using the stock length hose. /forums/images/graemlins/thumb.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    my truck had a drop down bracket and i belive i used a new stock brake line, plenty long with 12" lift! /forums/images/graemlins/peace.gif
  4. bigchevy80
    Aug 26, 2003
    40
    Any more?
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I used the NAPA rear line. Direct fit replacement and cost $14
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I'm in the same boat. If anyone has a number to a longer rear brake line it would be helpful. I need to buy another line anyway since the old one is bad and would rather get a longer one and do away with the drop extension bracket at the same time. /forums/images/graemlins/thinking.gif
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The search feature is your friend.
    Napa #4138068
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Now if I only had a Napa within 50 miles.... /forums/images/graemlins/smirk.gif
  9. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Guys, I have not had time to get the brake hose up on the we site yet but I can supply this one and others.
    Rubber hose 20" long @ 33.00
    Stainless hose 20" long @ 38.00
    Shipping 8.00 in lower 48 states
