Extended rear shock mount... Steve?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Aug 14, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Steve:
    When they did the rear shock mount between the frame rails, I see its 1 1/2" OD tube. Is that hollow? Thin or thick wall? I am considering doing this since the tank and diff is out of the way already.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  2. CK5
    May 19, 1999
    21,625
    702
    CO
    Hollow, thick I guess, but not sure.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I did some searching and found this old post of mine. Not sure if the price is the same now though.
    Well I did all the leg work and here is what I found.
    Scott at rockstomper.com (303-833-1431) can supply a kit like on Steve's K5 for around a $100.00 including shipping. The kit would include upper bar that would need to be cut to length (because frame widths vary) and the ends would need to be welded on. Lower mounts would need to be welded on also. Shocks (If you are running the same lift as Steve) you would need to get are Rancho part # RS9012 or similar. You will also most likely have to modify your exhaust. Hope this helps out. Thanks Steve for all your help!!!!!!
    Scott at rockstomper.com (303-833-1431) The phone # is also his fax #.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
