extended shackles noise
Discussion in 'OffRoad Design' started by one, Oct 22, 2003.
  1. one
    one Registered Member
    Aug 31, 2002
    28
    redwood city california usa
    I installed extended shackles in the front and the flip kit in the rear of my 88 k5(works great!) However, I am experiencing some clicking noises when I hit a bump at an angle when only one tire takes the hit..(noise is front and rear) could I have overtightened or under-tightened the shackles(front and rear)?
    help!
    thanks,
    Ben
  2. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Diagnosing a noise like this is really tough to do but the suspension hardware should be checked as part of the process. The front shackles should be tighted to 50 ft-lb, the rears to 90-110 ft-lb.
    I'm not sure where to start with other stuff to check, just about anything can cause the noise so a pretty thorough check is in order. Wheel bearings, ubolts, swaybar mounts, steering box bolts, etc, etc, etc.
    I know this is kind of vague but I hope it helps.
  3. one
    Aug 31, 2002
    28
    thanks,
    let the fun begin this weekend!
    ben
