extended shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79 K5, Feb 18, 2002.
  1. 79 K5
    79 K5 Registered Member
    Feb 18, 2000
    95
    NC
    I thought I saw a write up here a while back on using shock towers from an F250 on a Blazer to get extended shock travel. Can someone lead me to that write up, or explain it to me?... or tell me where to find a set of these front shock towers?
    If you don't come back dirty, it wasn't much fun.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    if you cant find the mounts at your dealer, try this:
    <a target="_blank" href=http://www.partsmike.com>www.partsmike.com</a>
    That's where I got mine.
    Here's steve's writeup.
    <a target="_blank" href=http://www.coloradok5.com/ranchoreview.shtml>http://www.coloradok5.com/ranchoreview.shtml</a>
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    heres the link
    http://coloradoK5.com/gallery/Pauls89K5
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just got a pair for around $30 from the local dealer. Do a search, the part numbers have been posted repeatedly on several posts in the last 2-3 weeks. I'm told the application listed in the article is not correct, you need the part number but they can still get them.
    Here, I went ahead and looked it up for you: E5TZ-18183A
    Search for "Ford Shock" and choose the "AND" option (not entire phrase).
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=329766&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>Here</a> is one of the recent threads:
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.<P ID="edit"><FONT class="small">Edited by BadDog on 02/18/02 11:05 AM.</FONT></P>
