Extending shackles front and rear
Discussion in 'The Garage' started by 78Jimmyish, May 20, 2002.
  1. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    Rhode Island
    Is extending the front and rear shackles a safe and economical way to gain an inch or two? What's a reasonable amount to lengthen them by. Obviously, I can't make shackles that are a foot longer than stock, but I was thinking about extending them each by two inches.
    BTW: I was planning on doing it out of 3/8 stainless plate - should be MORE than strong enough.
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    You can extend the front shackles by a little bit but you have to keep in mind that it will change the steering geometry/alignment. You also have to pay attention the angle of the front driveshaft since longer shackles will rotate the pinion down. I would not recommend more than an inch or so because of these issues. Also remember that the total amount of lift you gain will only be half of the extended length of the shackle, so in order to get 2" of lift you would need shackles that were 4" longer than stock.
    For the rear shackles, if they are still in the stock configuration you would actually lower the vehicle if they were lengthened.
