extending the reservoir on the power steering pump
Discussion in 'The Garage' started by surpip, Jul 11, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I know a lot of you guys have used the radiator hose to extend the pump reservoir, have the hoses held up ok? I know the rubber they are made with is not designed to stand up to ATF so i was wondering how the inside of the hose looked after a while
    and if anyone had a extra reservoir they can send me:D
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I used gas line. A foot of it was all of $2. Went to the hardware store and got a 1 3/4 galvy barbed/screw end to put a lid on and done.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    good idea ok
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Had mine for wel over 4 years and just filled it up yesterday and still no problem
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Mine looks fine after a year, but then again I use real power steering fluid as well.
    I've got one you can have. $700 and it comes with a free TBI 350 and 700R4.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Here is a couple pics of my set-up i added. The hose i used is P/S hose and is 3/4" diameter and the hydro-boost reservoir has a 3/4" nipple on the bottom that it attaches to and the power steering boot is a chrysler item and if you look i have the part number for it in my gallery. Ok, took the liberty to find the part number for you, #4333475 from a Chrysler dealer.
  7. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i use rad hose also... no problems in the errrrrr 2 years (?) that I've had it on there. Might be 3 by now.
    j
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    dude you rock ass!!!!!
    went to the parts store, couldent find the right PS pump for my truck the return hose line was pointing the wrong direction on all of them, so i will be rebuilding my own.
    good idea!!!
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    also one more question
    will a dubble ended ram work with assist?
    i only want to buy one ram(full hydro at a much later date) so i want a duble ended one now
  10. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Koldsimer told me to get the radiator hose that had the metal "coil" running through it so that when the fluid is pulled out it will not suck the hose down on itself as bad.
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You dont need that as long as your cap is venting properley.
