extened brake lines(new question)
Discussion in 'The Garage' started by 85mudblazin, Sep 11, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Extended brake hoses that are 25 7/8" long will fit 10bolt from 89-2000 2wd chevy/gmc from right front but will work for both sides and can be modified to fit a D44.
    Part #'s:
    Napa - 38872
    Raybestos - 38872
    Auto Specialty - HB-86045
    Coni-Seal - BH-177767
    Carquest - SP8820
    I found this in a older post and I was wondering, do you buy 2 right side brake lines or both the left and right side, I am a little confused /forums/images/graemlins/screwy.gif
    -Chris
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You buy 2 of the #38872 lines. It doesn't matter right to left.
    Harley
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok thanks /forums/images/graemlins/thumb.gif
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Harley
    How long are these? Can you put more than 2 of them together to get a longer line? I need a line that is 35-40" long for a D60 and can't find any... would this work?
    POOH
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I bought both right and left, didn't matter to me.
  6. grape ape
    grape ape Registered Member
    Jul 30, 2004
    9
    High Point, NC
    Yeah, I have the same question as PoohBair.
    I used the double brake lines listed above from Napa on my d44 front, but now have a D60 and need longer lines.
    Dean
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    How long are these?
    25 7/8" long
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    So what type of truck do we ask for is it an 89 -200 1/2 2 WD Chevy truck.
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Car Quest has them for $35 a piece. I might as well by the stainless braided ones for $80.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    People have had problems with braided lines. That's why we're looking for longer rubber ones.
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yikes. I purchased two P/N 38872's from Napa for $34 total.
    I finally did the brake line & longer shock install this past week. On my old truck it was less than a direct bolt on because the frame mounting holes are different. But, drilling out the caliper end for the 7/16" banjo bolt was easy. The #38872 lines are about 5" longer than stock and so far work great. /forums/images/graemlins/waytogo.gif
    FYI....the OEM application for the #38872 is a '94 C3500.
