external harddrive crapping
Discussion in 'The Lounge' started by 84gmcjimmy, Sep 20, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have an external hard drive.
    Last night when the computer was off, there was the orange WORKING light that comes on when your using it, i.e. transferrring files.
    Then we couldn't start the computer, or else it froze.
    Earlier that day I couldn't open ANY files on the external drive without either the folder freezing/"Not responding" or windows media player freezing too. Sometimes I couldn't even open it.
    Is it possible there was just a bug or something? I unplugged it and the PC ran fine. Busy doing a bunch of scans, just in case spyware was messing with me.
    any ideas?
  2. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    plugged it in for the first time since I unplugged it.
    At first the harddrive didn't show up on my computer. Then the 2nd try it did, when I clicked on it "my computer" folder froze and I had to force quit it.
    Whats wrong? I cant even access it?
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Failure? :doah:
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    What brand drive and computer Steve?
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Sounds like you're using a Mac. I'll guess you're using a firewire drive? These are most often simply IDE drives in a housing with a firewire convertor and power supply. If it's scsi (big connector with many pins), you might be at the end of the drives natural lifespan...
    I had some old Firewire Que external drives a few years ago that had a seriously flawed case design that allowed the drives to overheat. We'd get them replaced on warranty about once a year. I notice many newer external drives still have poor airflowing housings.
    If you can figure it out and the drive is definately not under warranty anymore, see if you can open the case/housing so the actual drive can breathe a little. Hard drives are like 700R4's, they don't like heat... If you do that and it's successful, get your data off the drive and kiss it goodbye. If you still don't see success, pull it out of the housing, open the computer up, and plug the drive directly into the IDE channel inside the computer (flat ribbon cable). That can get a little more complicated for someone unfamiliar with it, with slave/master and position on the wire, etc, though.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Nope im using windows.
    Windows XP home or professional, not sure what one.
    The harddrive is a Maxtor. and it uses a USB cable
    We've had it for a few years, but I dont think it should die that soon. It was 80 gigs and almost filled up :mad:
    It has cooling fins or "cracks" in the front, a few on the side, and most of the underside is covered up. I will check when the warranty ends before I attempt to open it up. Just so I dont void the warranty.
  7. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Any other problems or just freezing when you try to use the drive?
    Sounds like a communication error, software conflict, or it died a horrible death.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Just freezing when I try to use it. It either freezes the harddrive folder, or anything that runs from the folder, or needs to use it.
