external points of cage mounts???
Discussion in 'The Garage' started by MNorby, Jul 14, 2005.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I'm starting to install my Jegs cage in my truck. I want to put tube out the back of the cab into the bed. I have been reading about mounting the cage to the body only and not tying into the frame. How do you tie into just the body in the bed since the bed is hard mounted the the frame and the bed and body are 2 entities? I thought maybe putting a body mount under the tube in the bed area???? Any ideas? Thanks.
  2. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
  3. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Here is Bill P's big wheeler. He used bushings at both ends in those bars from the cab to the rear coilover mounts. Personaly I don't buy the frame cracking if you tie to it thing...but then again I never had a chevy body that was good enough that you could trust it. :doah:
  4. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I think I'll try that. Hey Rob, this is Matt in Powell, Joe's friend. I bought then sold that 12 bolt years back.
  5. rcurrier44
    Oct 13, 2003
    320
    I figured that was you...The rig is looking great! ;)
  6. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    Well, took the bushing idea and got my tubes in today. Used a set of spring bushings I had sitting around one one end and a set of freightliner hood bushings we had in the shop for the other end. Will do more supporting down on my rear cage square later and prob tie into my rear bumnper when I do that. Thanks for the idea in the first place :)
