External Pump to feed TBI??
Discussion in 'The Garage' started by sled_dog, Mar 20, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Whats a decent external pump to feed TBI? Most on Summit list something liek 12PSI(high carb pressure) and the fuel injection ones are something like 30 something and expensive.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    11-14 is tbi pressure, 40+ is MPFI setup, carb, is 6 or so.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    11-14 is stock TBI pressure. However this is going to be a 383 with 454 throttle body. I may need to push more pressure than that.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    What about a "normal" EFI pump and regulator setup, feeding the TBI regulator? Might be a little more than you wanted to spend, but it also might be the best way to do the job...
    Set the 1st regulator for like 20psi or so, and route it's output to the TBI regulator. I assume you're gonna run the vacuum-referenced regulator?
  5. blacksheep10
    blacksheep10 Registered Member
    Feb 16, 2005
    37
    Paola, KS
    ford ranger pump. Would have to ask my friend what model it is. Works well.
  6. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    hook up mechanical fuel pump on the block(if you can), plus your electric pump, join both fuel lines with a "T" fitting into your TBI...you'll get good pressure and volume. A friend did it for his 330HP 454...works good.
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Try this one that goes in the fuel rail. Napa part# 5001. I think its about $140.
  8. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Airtex E8094, it is made specifically for TBI conversions. I have sold a bunch of these and have only warrantied one in the past ten years. I think it is about the same price as the NAPA one mentioned previous, but you might be able to find it for less if you shop around. Good pump, not too noisey, lifetime warranty, comes as a complete kit--fittings, mounting clamps etc.
