Extra capacity transmission pan
Discussion in '1936-Present Suburban' started by BettyBurb, Jan 18, 2003.
  1. BettyBurb
    BettyBurb Registered Member
    Dec 14, 2002
    52
    NorthEast Colorado
    I am looking for an extra capacity transmission pan with a drain plug that will fit my 1988 Suburban with 700R4. I am concerned about clearance at the front driveshaft and exhaust pipe that crosses under the pan.
    This is a 1988, 1/2 ton, 350. Does anybody know of a pan that will fit without any problems ???
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Dunno if there's a stock one that holds more fluid. /forums/images/graemlins/confused.gif
    I've heard to stay away from the chrome aftermarket ones.... they are a poor stamping and don't seal well. You should be looking for a cast aluminum one instead.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    if you could find a cast steel one you could notch it for the shaft and weld in a plate to seal it up. /forums/images/graemlins/smile.gif /forums/images/graemlins/cool.gif or just lift the truck more! /forums/images/graemlins/thumb.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Try looking at the deep aluminum pans that Summit sells. They are better at cooling and add like 3 or 4 quarts. The pans are pretty thick and fixed the slow seeping problem I had.
  5. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
