Extrenal transmission filter
Discussion in 'The Garage' started by opfor2, Jun 3, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I'm going to add an external transmission filter the type that use the spin on oil filters and I was wondering how much stuff can the trans pump through before it looses pressure. Presently, I'm using the stock oil cooler, an external cooler, and now I want to add the filter. Any ideas?
    Dan..
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Adding a filter should not effect pressures.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Doesn't effect pressure..... If I had room, I'd run the long filter...
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Do these external filters do a better job of filtering or are they just added insurance? Guess my question is why use one?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    added insurance, easier to change so you can keep up on maintenence easier. A buddy of mine runs on on his Ranger, changes it once a year. Its right up front with his trans coolar.
  6. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    I like it but were is your coolant recovery bottle ???
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    think about it... It definitely adds to the filtering capabilty.. You can run different Micron rated filters too...
    In my case, someone gave it to me.... Definitely cheap insurance and by that I mean it's not a costly mod even when not a freebie.. Certainly makes maintenence on your tranny simple and easy to stay on top of..
    Opfor2.....
    There is no recovery bottle in the truck at the moment... I do have a trick one that goes right next to the radiator, but I'm waiting to put it in till I reconfigure that side with my sealed electronics box I'm building...
    Actually the filter will be relocated at that point up to the front because the sealed box is going in that spot behind the battery.. Still working out the details...
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    not only does it help filter junk... it adds fluid capacity. Always a good thing.
    j
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Im actually looking for an external filter and ive heard some come with a temp gauge....im thinking of getting one to install when i put in my transmission..
  10. tlspeed
    tlspeed Registered Member
    Apr 20, 2005
    75
    Arkansaw, WI
    I have an external filter like the one talked about. Picked it up at Napa for about $20. Then went to the hardware store and picked up A "T" and other fittings to tee in the trans cooler temp guage probe on top of the filter. Works great, no problems yet.
  11. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Ryoken, do you know who made your trans oil filter adapter? I looked at Summit and a few other auto parts places and all the trans filter adapters have the hose fittings on the top not the side like yours. I would like to get one with side hose mounts not top.
    thanks
    Dan..
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hmmm, I've had it forever... no part #'s on it, I always just assumed it was a Summit.. But I see what you mean, I don't see any listed like mine...
    I'll take a peek around tonight when I get home.. I know they make side mount ones for marine use...
  13. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    Hey ryoken can you repost the pic...I can see the one up there. And how do these hook in line? Do they screw in?
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    they all have NPT ports in them.. you can put any fitting in there, npt to barb, for running rubber hose to it (simplest, cheapest). or in my case, NPT to AN, for my steelbraided...
  15. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I have a similar one, made by Permacool I got from Jegs. It has a temp guage to.
  16. Dafey
    Feb 10, 2007
    2,675
    Roswell NM
    Its made specifically for trans? Do you have a # or web page?
    And I could use the gauge too , the one I have is a cheap piece of crap.
  17. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
